RG-CS83-24GT4XS-P,24-Port GE Electrical Layer 3 Managed Access Switch with PoE+
RG-CS83-12GT4XS-P
12 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS
24 x GE Electrical Ports, 4 x 10GE SFP+ Ports
RG-CS83-24GT4XS-P
24 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-48GT4XS
48 x GE Electrical Ports, 4 x 10GE SFP+ Ports
RG-CS83-48GT4XS-P
48 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS-P
24 x 1000 Mbps electrical ports and four 10G optical ports for flexible networking PoE+ supported, providing power to powered devices on security hybrid systems andwireless coverage systems
Flexible installation
Silence
Carrier-class Reliability
Make Your Business Easy
Flexible Management Modes
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
12 x 100M/1000M  BASE-T ports
support PoE+
24 x 100M/1000M BASE-T ports
48 x 100M/1000M BASE-T ports
support PoE+
support PoE+
78 Mpps
104 Gbps
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3.75 kg (8.27 lbs)
1.0 GHz dual-core CPU
< 35 W (non-PoE)
< 405 W (PoE full load)
< 40 W
< 35 W (non-PoE)
< 52 W (non-PoE)
< 460 W (PoE full load)
409 W
Maximum  PoE output :370W
409 W
460 W
Maximum  PoE output :405W
100 V AC to 240 V AC
24.14 years
23.74 years
23.85 years
23.94 years
22.86 years
27℃: < 35 dB
< 20 dB
27℃: < 32 dB
27℃: < 35 dB
27℃: < 35 dB
Communication port: 10 kV
Coating Conformal
RG-CS83 Series
SPAN, RSPAN
Interface priority
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
