RG-CS85-48SFP4XS-D Switches - 1
RG-CS85-48SFP4XS-D Switches - 2
RG-CS85-48SFP4XS-D Switches - 3
RG-CS85-48SFP4XS-D Switches - 4
RG-CS85-48SFP4XS-D Switches - 5
RG-CS85-48SFP4XS-D Switches - 6
RG-CS85-48SFP4XS-D Switches - 7
RG-CS85-48SFP4XS-D Switches - 8
RG-CS85-48SFP4XS-D Switches - 9
RG-CS85-48SFP4XS-D Switches - 10
RG-CS85-48SFP4XS-D Switches - 11
RG-CS85-48SFP4XS-D Switches - 12
RG-CS85-48SFP4XS-D Switches - 13
RG-CS85-48GT4XS-HPD
48 x 1GE RJ45 ports, 4 x 10GE SFP+ports, PoE/PoE+
RG-CS85-48SFP4XS-D
48 x 1GE SFP ports, 4 x 10GE SFP+ ports
RG-CS85-48GT4XS-D
RG-CS85-24SFP/8GT8XS-D
24 x 1GE SFP ports (with eight combo ports), 8 x 10GE SFP+ ports
RG-CS85-24GT8XS-D
24 x 1GE RJ45 ports, 8 x 10GE SFP+ ports
Key Specifications View More
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
8 x 1GE/10GE SFP+ ports
24 x 1GE SFP ports
CM85-4XS2CQ
M2SFAN I-F (pre-installed 2)
Module service port
CM85-4XS2CQ:
● 4 x 1GE/10GE SFP+ ports
● 2 x 40GE/100GE QSFP28 ports
1 x USB 3.0 port
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Flash Memory
4 GB
1 GB
1 GB
1 GB
2 GB
Switch buffer
4 MB
Ingress: 7,000
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
Unit dimensions
(W x D x H)
440 mm x 340 mm x 44 mm
Shipping dimensions
(W x D x H)
593 mm x 497 mm x 192 mm
563 mm x 563 x mm 210 mm
4.4 kg
(9.70 lbs)
(9.48 lbs)
(9.92 lbs)
5.3 kg
(11.68 lbs)
5.7 kg
(12.57 lbs)
6.20 kg
(13.67 lbs)
6.62 kg
(14.59 lbs)
6.30 kg
(13.89 lbs)
7.70 kg
(16.98 lbs)
7.80 kg
(17.20 lbs)
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-PA150IB-F (AC input):
RG-CS85-48GT4XS-HPD
120 W (without PoE)
1,600 W (full PoE load)
● 2 x RG-PA600I-P-F: 740 W
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
3 x fixed fan modules
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85 Series
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
CM85-4XS2CQ
