RG-S5000-10GT2MS-E Switches - 1
RG-S5000-10GT2MS-E Switches - 2
RG-S5000-10GT2MS-E Switches - 3
RG-S5000-10GT2MS-E Switches - 4
RG-S5000-10GT2MS-E Switches - 5
RG-S5000-10GT2MS-E Switches - 6
RG-S5000-10GT2MS-E Switches - 7
RG-S5000-10GT2MS-E Switches - 8
RG-S5000-10GT2MS-E Switches - 9
RG-S5000-10GT2MS-E Switches - 10
RG-S5000-10GT2MS-E Switches - 11
Key Specifications View More
RG-S5000-10GT2MS-E
Local & Cloud O&M
Visualized Management
Alarm Processing
RG-S5000-10GT2MS-E
RG-S5000-10GT2MS-P-E
RG-S5000-24GT4MS-E
RG-S5000-24GT4MS-P-E
RG-S5000-48GT4MS-E
2 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
24 x
4 x 2.5G/1GE SFP ports
4 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
1 x fixed module
1 x fixed module
2 x fixed modules
2 x fixed modules
27 Mpps
27 Mpps
104 Mpps
System switching capacity *
139 Gbps
256
Weight (full load)
2 kg (4.41 lbs)
2.5 kg (5.51 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.8 kg (6.17 lbs)
ARM Cortex A9, 1.2 GHz
64 MB flash memory
16 W
141 W (PoE power: 125 W)
430 W (PoE power: 370 W)
> 200K
> 200K
> 200K
> 200K
> 200K
≤40 dB
≤40 dB
≤40 dB
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Others
Installation mode
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
Expert ACLs
Port rate limiting
IEEE 802.1X authentication
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
Load balancing modes
TFTP (TFTP client)
SSH v1.5/v2.0
l IEEE 802.3af and 802.3at
l Port priority
Cloud
WIS
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
