RG-CS86-20XS4VS2QXS-D Switches - 1
RG-CS86-20XS4VS2QXS-D Switches - 2
RG-CS86-20XS4VS2QXS-D Switches - 3
RG-CS86-20XS4VS2QXS-D Switches - 4
RG-CS86-20XS4VS2QXS-D Switches - 5
RG-CS86-20XS4VS2QXS-D Switches - 6
RG-CS86-20XS4VS2QXS-D Switches - 7
RG-CS86-20XS4VS2QXS-D Switches - 8
RG-CS86-20XS4VS2QXS-D Switches - 9
RG-CS86-20XS4VS2QXS-D Switches - 10
20 x 10GE SFP+ ports, 4 x 25GE SFP28 ports, 2 x 40GE QSFP+ ports
and Network Connectivity
Fixed Ports
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports. One switch provides a maximum of 32 x 10GE ports, 2 x modular power slots, and 2 x modular fan slots.
Fan module
Dual pluggable modular fans, with front-to-rear ventilation channels
2 x replaceable hot-swappable power supply slots
570 Mpps
760 Gbps
32,768
In: 2,500
Out: 1,000
440 x 330 x 43.6 mm (17.32 in. x 12.99 in. x 1.72 in.), 1 RU
Weight of the empty chassis
4.6 kg (10.14 lbs.)
Dual-core CPU, 1.25 GHz
4 MB
Supported power module type: RG-PA150I-F
Maximum voltage range: 90–264 V AC; 47/63 Hz
Rated input current: 3 A
< 85 W
RG-PA150I-F: 150 W
RG-PA150I-F:
RG-PA150I-F:
Power port: 6 kV/6 kV
Temperature alarm
Coating Conformal
Super VLAN, private VLAN
Telnet
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports, supports up to 32 x 10GE ports, 2 x slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 x slots for fan modules, 2 x pre-installed fans (Purchase at least one RG-PA150I-F module.)
150 W AC power supply module for RG-CS86-20XS4VS2QXS-D
1000BASE-GT mini GBIC conversion module
SFP BiDi transceiver-Tx1310/Rx1550, 20 km, LC
SFP BiDi transceiver-Tx1550/Rx1310, 20 km, LC
SFP BiDi transceiver-Tx1310/Rx1550, 40 km, LC
SFP BiDi transceiver-Tx1550/Rx1310, 40 km, LC
SFP 2.5G BiDi transceiver-Tx1310/Rx1550, 3 km,LC
SFP 2.5G BiDi transceiver-Tx1550/Rx1310, 3 km,LC
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 300 m
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 10 km
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 40 km
25G fiber module
25G fiber module
10G SFP+ connector fiber, 1-meter long, including one cable and two connector modules
10G SFP+ connector fiber, 3-meter long, including one cable and two connector modules
10G SFP+ connector fiber, 5-meter long, including one cable and two connector modules
25G Base SFP+ fiber cable (including modules on both ends), 5-meter long
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8-core, 850 nm wavelength, max cabling distance: 100 m (OM3), 150 m (OM4)
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10 km (LC, dual-core, 1310 nm wavelength)
40G QSFP+ connector fiber, 5-meter long, including one cable and two connector modules
40G QSFP+ connector fiber, 10-meter long, including one cable and two connector modules
