RG-CS85-24SFP/8GT8XS-D 24-Port GE Optical Layer 3 Enterprise-Class Core or Aggregation Switch (with Eight Combo Ports), Eight 10G Uplink Ports
  • Rich port types, 24-Port GE Optical Ports (with Eight Combo Ports), and 8 × 10G optical ports for uplink
Key Specifications View More
Layer 3 GE Core & Aggregation Switch RG-CS85-24SFP/8GT8XS-D
Aggregation switch for small and medium-sized campus networks, with eight 10G uplink optical ports for high-speed data transmission; 24-Port GE Optical Ports (with Eight Combo Ports), providing high-speed network experience for long-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
24 x 10/100/1000BASE-T ports, 8 x 1GE/10GE SFP+ ports
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports
48 x 10/100/1000BASE-T ports, PoE/PoE+ supported, 4 x 1GE/10GE SFP+ ports
Fan module
3 fixed fans
3 fixed fans
3 fixed fans
2 modular fans
3 modular fans
Expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Ingress: 7,000
4.4 kg (9.70 lbs)
5.5 kg (12.12 lbs)
5.3 kg (11.68 lbs)
Dual-core CPU, 1.2 GHz
4 GB
4 GB
4 GB
4 GB
4 GB
<110 W (non-PoE)
<1,590 W (PoE full load)
<150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
176 V AC to 290 V AC, 1000 W
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
200 V to 240 V
DC: -48 V to -60 V
AC: 100 V to 240 V
DC: -48 V to -60 V
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V
AC: 176 V to 264 V
DC: -38 V to -75 V
AC: 90 V to 264 V
DC: -36 V to -75 V
≥ 1,051,000 hours
≥ 823,000 hours
≥ 963,000 hours
≥ 832,000 hours
≥ 788,000 hours
45°C: 56.2 dB
45°C: 57.1 dB
45°C: 57.9 dB
27°C: 50 dB
45°C: 65 dB
27°C: 53 dB
45°C: 68 dB
Power port: 6 kV/6 kV
RG-CS85 Series
RG-CS85-24GT8XS-D
24 x 10/100/1000BASE-T ports, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-D
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-HPD
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.)
RG-CS85-48SFP4XS-D
CM85-4XS2CQ
150 W AC power supply module
