RG-CS86-24MG4VS-UP Switches - 1
RG-CS86-24MG4VS-UP Switches - 2
RG-CS86-24MG4VS-UP Switches - 3
RG-CS86-24MG4VS-UP Switches - 4
RG-CS86-24MG4VS-UP Switches - 5
RG-CS86-24MG4VS-UP Switches - 6
RG-CS86-24MG4VS-UP Switches - 7
RG-CS86-24MG4VS-UP Switches - 8
RG-CS86-24MG4VS-UP Switches - 9
RG-CS86-24MG4VS-UP Switches - 10
RG-CS86-24MG4VS-UP Switches - 11
RG-CS86-24MG4VS-UP 24-Port Multi-GE Switch with Cloud Management, Full 1GE/2.5GE/5GE Access with PoE++
RG-CS86-12XMG4VS-UP
12 x 10GE RJ45 ports, 4 x 25GE SFP28 ports
RG-CS86-24MG4VS-UP
24 x 5GE RJ45 ports, 4 x 25GE SFP28 ports
RG-CS86-24XMG4XS4VS-UPD
24 x 10GE RJ45 ports, 4 x 10GE SFP+ ports, 4 x 25GE SFP28 ports
RG-CS86-48MG4VS2QXS-UPD
48 x 5GE RJ45 ports, 4 x 25GE SFP28 ports, 2 x 40GE QSFP+ ports
  • 24 x 100/1000/2.5G/5GBASE-T ports for access, 4 x 10GE/25GE ports for uplink, meeting high-bandwidth campus network demands
Multi-GE Switch
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
24 x 100/1000/2.5G/5GBASE-T ports, supporting PoE/PoE+/PoE++;
4 x 10GE/25GE SFP28 ports
  • Ports 1 to 48 support PoE/PoE+
  • Ports 1 to 24 support PoE++;
24 x 100/1000/2.5G/5G/10GBASE-T ports, supporting PoE/PoE+/PoE++;
4 x 10GE/25G SFP28 ports
12 x 100/1000/2.5G/5G/10GBASE-T ports, supporting PoE/PoE+/PoE++;
Fan module
2 fixed fans
3 modular fans
3 modular fans
2 fixed fans
1 Built-in power module
1 x MGMT port
1 x MGMT port
1 x MGMT port
1 x MGMT port
327 Mpps
625 Mpps
565 Mpps
327 Mpps
440 Gbps
840 Gbps
760Gbps
440 Gbps
32,768
Egress:1,000
3.65 kg (8.82 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
3.65 kg (8.82 lbs.)
ARM processor, 1.25 GHz
Full PoE load: < 370 W
Full PoE load: < 1600 W
Full PoE load: < 1650 W
460W
460W
Rated Input Voltage
PoE-capable Port
22.18 years
27.02 years
22.18 years
22.18 years
Front/Left-to-rear airflow
Surge Protection
6 kV
6 kV
6 kV
6 kV
Temperature Monitoring
Temperature alarm
Temperature alarm
Temperature alarm
Temperature alarm
Coating Conformal
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
GR for RIP, OSPF, BGP
Switch and Power Module
RG-CS86-24MG4VS-UP
fixed AC power supply and fan
RG-CS86-12XMG4VS-UP
GE Optical Module
10GE Optical Module
50 μm/125 μm: 66 m over MMF
2000 MHz·km: 300 m over MMF
25GE Optical Module
40GE Optical Module
