RG-CS83-48GT4XS-PD Switches - 1
RG-CS83-48GT4XS-PD Switches - 2
RG-CS83-48GT4XS-PD Switches - 3
RG-CS83-48GT4XS-PD Switches - 4
RG-CS83-48GT4XS-PD Switches - 5
RG-CS83-48GT4XS-PD Switches - 6
RG-CS83-48GT4XS-PD Switches - 7
RG-CS83-48GT4XS-PD Switches - 8
RG-CS83-48GT4XS-PD Switches - 9
RG-CS83-48GT4XS-PD Switches - 10
RG-CS83-48GT4XS-PD Switches - 11
RG-CS83-24GT4XS-PD
24 x 1GE RJ45 ports, 4 x 10GE SFP+ ports, PoE/PoE+
RG-CS83-48GT4XS-PD
48 x 1GE RJ45 ports, 4 x 10GE SFP+ ports, PoE/PoE+
Key Specifications View More
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
Fans modules
Power modules
8,000
VLAN translation
4,094
4.3 kg (9.48 lbs)
4.6 kg (10.14 lbs)
3 MB
< 65 W (non-PoE)
< 810 W (PoE full load)
< 75 W (non-PoE)
< 1570 W (PoE full load)
176 V AC to 290 V AC, 1000W
RG-PA600I-P-F:
HVDC: 240 V DC
HVDC: 240 V DC
RG-PA600I-P-F:
HVDC: 192 V DC to 288 V DC
27°C: 51.6 dB
45°C: 57.4 dB
27°C: 51.6 dB
45°C: 58.3 dB
Power port: 6 kV/6 kV
Coating Conformal
RG-CS83-PD Series
PIM-SMv6, PIM-SSM v6
Traffic policing: CAR
Allowlist
CPP(CPU Protection Policy)
RG-CS83-24GT4XS-PD
24 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 740 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.)
RG-CS83-48GT4XS-PD
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 1480 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.)
