RG-S6580-48CQ8QC Switches - 1
RG-S6580-48CQ8QC Switches - 2
RG-S6580-48CQ8QC Switches - 3
RG-S6580-48CQ8QC Switches - 4
RG-S6580-48CQ8QC Switches - 5
RG-S6580-48CQ8QC Switches - 6
RG-S6580-48CQ8QC Data Center 100G High-Density Fixed Access Switch with 400GE Uplink(Backward Compatibility with 100GE)
High-density 400GE/100GE ports, supporting high-bandwidth and large-capacity server access
  • Various ports, and 48 x 100GE DSFP and 8 x 400GE QSPF-DD ports, supporting flexible networking
  • Hardware-level redundancy, ensuring nonstop services
  • Lossless Ethernet, ensuring zero packet loss in RDMA E2E communication
  • Telemetry network monitoring and automatic O&M, making management simple and efficient
Data Center 100GE Access Switch RG-S6580-48CQ8QC
The RG-S6580-48CQ8QC is a high-density access switch and provides various ports within the space of 1 RU. With improved data forwarding capabilities, it can be flexibly deployed and supports access of 100G servers. It can evolve to 100GE/400GE data centers.
Hardware-Level Redundancy, Ensuring Nonstop Services
1+1 power modules, hot swapping, and service failover within seconds, ensuing service continuity
Lossless Ethernet, Ensuring Zero Packet Loss in RDMA E2E Communication
With RDMA enabled, communication data on the RG-S6580-48CQ8QC does not need to be handled by the CPU. This reduces the burden of the CPU and effectively resolves the latency problem. Using PFC and ECN, the RG-S6580-48CQ8QC intelligently exchanges data to prevent packet loss and ensures lossless data transmission.
Telemetry Network Monitoring and Automatic O&M, Making Management Simple and Efficient
RG-S6580-48CQ8QC enabled with Telemetry uses the push mode to proactively collect and push information and provides sub-second-level network monitoring in real time, making network management more efficient and accurate.
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
48 × 100GE ports (DSFP) + 8 × 400GE ports (QSFP-DD)
24 × 200GE ports (QSFP56) + 8 × 400GE ports (QSFP-DD)
Expansion Module Slots
Two power supply module slots (1+1 redundancy)
Six fan module slots (5+1 redundancy; at least 5 fan modules are required)
16.0 Tbps
5350 Mpps
4094
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
Dimensions (W × D × H)
442 mm x 700 mm x 44 mm (17.40 in. x 27.56 in. x 1.73 in., 1 RU)
442 mm x 670.8 mm x 43.6 mm (17.40 in. x 26.41 in. x 1.72 in., 1 RU)
Chassis with six fan modules and two power supply modules: 11.5 kg (25.35 lbs.)
Chassis with six fan modules and two power supply modules: 11 kg (24.25 lbs.)
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
Power Input
RG-PA1200I-F module
● Rated voltage range: 100 V AC to 127 V AC (50 Hz to 60 Hz), rated current: 13.8 A
● Rated voltage range: 200 V AC to 240 V AC (50 Hz to 60 Hz), rated current: 8.5 A
HVDC input
RG-PA1200I-F module
● Rated voltage: 240 V DC
● Max voltage range: 180 V DC to 300 V DC
● Max input current: 6.5 A
Maximum Power Consumption
● Max: 742 W
● Typical: 633 W
● Static: 178 W
● Max: 850 W
● Typical: 700 W
● Static: 300 W
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
Temperature Alarm
Temperature alarms and overheat protection
10% RH to 90% RH (non-condensing)
Working altitude
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
L2 Protocols
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, Policy-based Routing (PBR), route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP
IPv6 Basic Protocols
ACL 80、ACL-based Redirection、IPv6 ACL、Extended/Standard IP/MAC-based ACL、Time-based ACL、Global ACL、When an ACL is applied to different physical interfaces or SVIs, resources can be shared.、ACL Counter、ACL Counter Only、ACL Logging、Diplaying ACL Resource Usage、Expert-level ACL、IPv4 UDF ACL、Global ACL Counter Only、Matching Against the Inner 5-Tuple of the VXLAN、IPv6 UDF ACL、Matching Against the Inner 5-Tuple of the Passing VXLAN、Ingress/Egress ACLs
ACL80、ACL-based redirection、IPv6 ACL、Extended/Standard IP ACL、Extended MAC ACL、Time-based ACL、Global ACL、Resource sharing in the case of applying an ACL on different physical ports or SVIs、ACL counter、ACL counter only、ACL logging、Displaying ACL resource usage、ACL-based re-marking、Expert-level ACL、IPv4 user-defined function(UDF) ACL、Configuring ACL counter-only globally、ACL matching against the inner 5-tuple of VXLAN packets、IPv6 UDF ACL、ACL matching against the inner 5-tuple of packets passing through the VXLAN
Data Center Features
RDMA
sFlow sampling
HA Design
Security Features
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm
DHCP client, DHCP relay, DHCP server, DNS client, ARP proxy, and Syslog
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
● BS EN 62368-1
● BS EN 55032
● BS EN 55035
● EN 61000-3-2
● BS EN 61000-3-2
● BS EN 61000-3-3
● EN 300 386
● VCCI-CISPR 32:2016
  • Select the switch (installed with all fan and power supply modules).
Chassis, Fan Module
RG-S6580-48CQ8QC
48 × 100GE DSFP ports + 8 × 400GE QSFP-DD ports
Two power slots and six fan slots
The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules.
RG-S6580-24DC8QC
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports
Power Supply Module
RG-PA1200I-F
1200 W AC module (AC/240 V HVDC)
Fan Module
M1HFAN II-F
Fan module (front-to-rear ventilation)
400G-QDD-SR8-MM850
400G SR8 module, QSFP-DD form factor, MPO-16 APC, 850 nm, 100 m (328.08 ft.) over MMF
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
