Model (Non-PoE) |
RG-PF2920-8GT2MG2XS |
RG-PF2920-16GT2XS |
Fixed ports |
8 x 10M/100M/1000M auto-negotiation electrical ports 2 x GE/2.5GE auto-negotiation electrical ports 2 x 10GE SFP/SFP+ ports |
16 x 10M/100M/1000M auto-negotiation electrical ports 2 x 10GE SFP/SFP+ ports |
Switching capacity |
66 Gbps |
72 Gbps |
Packet forwarding rate |
49.1 Mpps |
53 Mpps |
SFP+ port |
10GBase-R and 1000Base-X supported |
Power supply |
Powered by a hybrid cable from the PoF switch 2 x PoE inputs (802.3at): PoE-IN1 and PoE-IN2 Rated voltage range: 44 V to 57 V Rated current: 0.5 A |
Leakage current to ground |
≤ 3.5 mA |
EEE energy saving |
Supported |
PoE output |
Not supported |
Max. power consumption |
< 20 W |
Installed on a wall or cable tray or in a rack: 0ºC to 55ºC (32ºF to 131ºF) at a height below 1,800 m (1.12 miles) above the sea level Note: At a height ranging from 1800 m (1.12 miles) to 5000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.). |
10% to 90% RH |
5% to 95% RH |
Fan |
Intelligent temperature control |
The temperature alarm and overheat protection functions are supported. |
Electromagnetic compatibility (EMC) |
GB/T 9254.1-2021 |
Safety standard |
GB 4943.1-2022 |
Dimension (W x D x H) |
210 mm x 235 mm x 55 mm (8.27 in. x 9.25 in. x 2.17 in.) |
2.75 kg (6.06 lbs, including the package) |
Model (PoE) |
RG-PF2920U-4GT1MS-P |
RG-PF2920-DPBOX-P |
Fixed ports |
4 x 10M/100M/1000M auto-negotiation electrical ports 1 x 1000M/2.5G SFP port |
1 x 10M/100M/1000M auto-negotiation electrical port 1 x GE SFP port |
13 Gbps |
N/A |
9.7 Mpps |
N/A |
SFP port |
2500Base-X and 1000Base-X supported |
Power supply |
Powered by a hybrid cable from the PoF switch Maximum voltage range: 42 V DC to 57 V DC Rated voltage range: 44 V DC to 56 V DC Rated current: 1.3 A |
Powered by a hybrid cable from the PoF switch Rated voltage: 44 V DC to 57 V DC Rated current: 0.75 A |
≤ 3.5 mA |
N/A |
EEE |
Supported |
Not supported |
Ethernet electrical ports 1–4 support PoE. Max. overall PoE output power: 60 W The maximum number of PoE devices supported by the switch is determined by the PoE output power of the switch and the actual power of the PoE devices. |
1 x downlink POE/POE+ port |
Overall power consumption |
Without PoE load: ≤ 15 W With PoE full load: ≤ 75 W |
Without PoE load: ≤ 3 W Overall power (PoE+) ≤ 33 W |
Installed in a rack or unconfined space: 0ºC to 45ºC (32ºF to 113ºF) at a height below 1,800 m (1.12 miles) above the sea level Installed on a workbench or in an ELV box: 0ºC to 40ºC (32ºF to 104ºF) at a height below 1,800 m (1.12 miles) above the sea level Note: At a height ranging from 1800 m (1.12 miles) to 5000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.). |
10% to 90% RH |
10% to 90% RH |
5% to 90% RH |
5% to 95% RH |
Fan |
Not supported |
GB/T9254.1 |
GB/T9254.1 |
Safety standard |
GB 4943.1 |
GB 4943.1 |
200 mm x 170 mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.) |
120 mm x 25 mm x 40 mm (4.72 in. x 0.98 in. x 1.57 in.) |
1.5 kg (3.30 lbs, including the package) |
0.2 kg (0.44 lbs, including the package) |
Model (Non-PoE) |
RG-PF2920-16GT2XS |
Max. number of MAC address entries |
Static MAC addresses MAC address filtering |
802.1Q VLAN |
4K IEEE 802.1Q VLANs Port-based VLAN MAC-based VLAN Private VLAN Protocol-based VLAN GVRP VLAN Voice VLAN |
QinQ |
Basic QinQ Selective QinQ |
Port aggregation |
Load balancing LACP dynamic aggregation The LACP priority, negotiation mode, and maximum number of ports that can be aggregated can be configured. VSU aggregated port |
Mirroring |
One-to-one mirroring, one-to-many mirroring, and many-to-one mirroring Flow- and VLAN-based SPAN RSPAN and ERSPAN |
DHCP |
DHCP server DHCP client DHCP relay DHCP Snooping |
IP routing |
Static black hole routing, RIP, OSPF, and RIPng |
ACL |
Standard IP ACL (IP-based hardware ACL) Extended IP ACL (hardware ACL based on the IP address or TCP/UDP port ID) Extended MAC ACL (hardware ACL based on the source MAC address, destination MAC address, and optional Ethernet type) ACL 80 IPv6 ACL Global ACL ACL redirection |
QoS |
Port traffic identification Port traffic rate limiting IEEE 802.1p/DSCP traffic classification Queue scheduling mechanisms such as SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, and SP+DRR |
Filtering of invalid MAC addresses Broadcast storm suppression Hierarchical management and password protection RADIUS and TACAS+ SSH and SSH V2.0 CPP and NFPP Port protection |
EEE |
EEE LPI mode on ports of the IEEE802.3az standard |
Management |
SNMP, Telnet, Web, RMON, FTP, TFTP, NTP/SNTP, RLDP, and Syslog/Debug |
Model (PoE) |
RG-PF2920-DPBOX-P |
802.1Q VLAN |
4K IEEE 802.1Q VLANs Port-based VLAN |
Not supported |
DHCP |
DHCP client |
Not supported |
Filtering of invalid MAC addresses Broadcast storm suppression Password protection CPP Port protection |
Not supported |
EEE |
APD port sleeping |
Not supported |
Management |
CLI-based configuration and management not required, visualized Web management IoT MQTT Syslog/Debug and SNTP |
Not supported |
The 8-port non-PoE switch provides 2 x 10GE uplink optical ports, 8 x 10M/100M/1000M downlink auto-negotiation electrical ports, and 2 x GE/2.5GE auto-negotiation ports, and supports power supply over the hybrid cable (10GE SFP+ port and PoE power supply input. A wide operating temperature range of 0°C to 55°C (32°F to 131°F) is supported, and an optical link fault LED is provided. |
RG-PF2920-16GT2XS |
The 16-port non-PoE switch provides 2 x 10GE uplink optical ports, and 16 x 10M/100M/1000M auto-negotiation electrical ports, and supports power supply over the hybrid cable (10GE SFP+ port and PoE power supply input). A wide operating temperature range of 0°C to 55°C (32°F to 131°F) is supported, and an optical link fault LED is provided. |
The 4-port PoE/PoE+ switch provides 1 x uplink GE optical port and 4 x downlink 10M/100M/1000M auto-negotiation electrical ports, and is connected to the hybrid cable (1 x GE/2.5GE SFP port and a round DC plug). The switch supports PoE/POE+ power supply of 4 x 15 W (or 2 x 30 W). A fanless design is adopted, and an optical link fault LED is provided. |
RG-PF2920-DPBOX-P |
The single-port media converter is connected to a hybrid cable in the uplink direction (GE SFP port + circular DC socket) and provides a PoE/PoE+ port in the downlink direction. |
