RG-S6120-20XS4VS2QXS |
Fixed por |
20 x 1G/2.5G/10G SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports One switch provides a maximum of 32 x 10G ports, 2 modular power slots, and 2 modular fan slots. |
Fan module |
2 x pluggable fan modules, and fan speed regulating and alarm function |
Power modules |
2 x power module slots |
Fixed management ports |
Packet forwarding rate |
570 Mpps |
System switching capacity |
760 Gbps |
Number of MAC addresses |
16,000 |
ND table size |
4,000 |
16,000 |
4,000 |
16,000 |
2,000 |
Maximum number of ingress ACEs associated with an SVI, physical interface, or aggregate interface: 2,500 Maximum number of egress ACEs associated with an SVI, physical interface, or aggregate interface: 1,000 |
Number of VSU members |
2 |
Number of IGMP groups |
4,000 |
Number of MLD groups |
1,024 |
Number of VRFs |
100 |
442 mm × 330 mm × 43.6 mm (17.40 in. x 12.99 in. x 1.72 in.), 1 RU |
Weight (full load) |
5.7 kg (12.57 lbs) |
1.25 GHz ARM processor |
Storage |
Flash memory: 1 GB |
4MB |
Power and Consumption |
< 85 W |
Rated input voltage |
RG-PA150I-F: AC input: Rated voltage range: 100–240 V AC; 50/60 Hz Rated input current: 3 A
HVDC input: Rated voltage: 240 V DC Rated current per circuit: 3 A |
RG-PA150I-F: AC input: 90–264 V AC; 47/63 Hz HVDC input: 192–288 V AC |
> 200,000 hours |
Primary airflow |
Front-to-rear airflow |
0°C to 50°C (32°F to 122°F) |
Maximum operating altitude |
5000 m (16404.20 ft.) |
Operating noise |
< 78 dB |
Interface surge protection |
Power module: 6 kV |
Feature |
Ethernet Switching |
Super-VLAN and private VLAN |
LACP (IEEE 802.3ad) |
IP Service |
Static and dynamic ARP |
DHCPv6 Client, DHCPv6 relay, and DHCPv6 snooping |
IP Routing |
OSPFv2 and OSPFv3 |
GR |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
BGP4 and MP-BGP |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 and IGMP proxy |
IGMPv1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 and IPv6 |
MLDv1/v2 |
MLDv1/v2 snooping |
MSDP |
PIM-SMv6 |
Multicast source IP address check Multicast source port check Validity check of IGMP packets |
Multicast querier |
Time-based ACLs |
ACL80 and IPv6 ACL |
Port traffic identification |
Port traffic rate limiting |
Traffic classification based on ToS values |
Eight queues on each port |
Rate limiting in each queue |
AAA |
RADIUS and TACAS+ |
Filtering of invalid MAC addresses Broadcast storm suppression Hierarchical management of administrators and password protection BPDU guard |
SSHv1 and SSHv2 |
ICMPv6 |
Port security |
SAVI |
ARP spoofing prevention |
REUP |
BFD |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP, SNTP, and NTP for IPv6 |
FTP and TFTP FTP/TFTP v6 |
SNMP v1/v2/v3 SNMP over IPv6 |
NETCONF |
CWMP |
CLI (Telnet/console) Syslog IPv6 MIB support for SNMP Telnet v6 Traceroute v6 DNS v6 |
20 x 1G/2.5G/10G SFP+ optical ports, 4 x 10G/25G SFP28 optical ports, and 2 x 40G QSFP+ optical ports, and up to 32 10G ports 2 x power module slots (at least one RG-PA150I-F power module needs to be configured) 2 x fan module slots (the device is equipped with two fan modules upon delivery) |
RG-PA150I-F |
150 W AC power module that applies to the RG-S6120-20XS4VS2QXS |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
2.5G-SFP-LX03-SM1310-BIDI-I |
SFP 2.5G BIDI Transceiver-TX1310/RX1550,3km,LC |
2.5G-SFP-LX03-SM1550-BIDI-I |
SFP 2.5G BIDI Transceiver-TX1550/RX1310,3km,LC |
10GE LC connector module, applicable to the SFP+ port 62.5 μm/125 μm: 33 m 50 μm/125 μm: 66 m Modal bandwidth of 2000 MHz·km for a link length of up to 300 meters |
10GE LC connector module with a link length of up to 40 km, 1310-nm wavelength, applicable to the SFP+ port |
10GE LC connector module with a link length of up to 40 km, 1550-nm wavelength, applicable to the SFP+ port |
10GE SFP+ port cable, 1 m, including one cable and two interface modules |
10GE SFP+ port cable, 3 m, including one cable and two interface modules |
10GE SFP+ port cable, 5 m, including one cable and two interface modules |
VG-SFP-SR-MM850 |
VG-SFP-LR-SM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40GE SR, QSFP+ transceiver, applicable to QSFP+ ports OM3 and OM4 MMF, MPO, 8-core, 850-nm wavelength, 100 m over OM3 MMF or 150 m over OM4 MMF |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
