The switch size is smaller than that of the previous generation. The regulation-compliant open area, excellent space layout, and right-angle power plug ensures security. The innovative shark fin design increases the heat dissipation area and improves heat dissipation efficiency, making the operation safer.
The switch can be used in combination with the INC controller, to implement fast onboarding, plug and play, and no commissioning. The link fault locating function, together with the INC controller, allows you to check the link health status and alarms, improving the troubleshooting efficiency and achieving zero touch replacement. Traffic routes do not need to change, and different switches can be flexibly used for replacement as required.
