RG-SF2920-8GT2MG2XS, 8-Port GE All-Optical Switch, 2 × 2.5G Electrical Ports (Backward Compatible),
Technical Specifications
4 × 10/100/1000M adaptive electrical ports, 1 × 1000M/2.5G SFP port, fixed single AC power supply; electrical ports 1–4 support PoE/PoE+; maximum PoE output power: 45 W
8 × 10/100/1000M adaptive electrical ports, 1 × 1000M/2.5G SFP optical port, fixed single AC power supply
8 × 10/100/1000M adaptive electrical ports, 1 × 1000M/2.5G SFP+ port, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W
8 × 10/100/1000M adaptive electrical ports, 2 × 1000M/2.5G adaptive ports, 2 × 1/10G SFP+ ports, fixed single AC power supply
16 × 10/100/1000M adaptive electrical ports, 2 × 1000M/2.5G adaptive ports, 2 × 1/10G SFP+ ports, fixed single AC power supply
16 × 10/100/1000M adaptive electrical ports, 2 × 1G SFP optical ports, fixed single AC power supply
16 × 10/100/1000M adaptive electrical ports, 2 × 1G SFP ports, fixed single AC power supply; electrical ports 9–16 support PoE/PoE+; maximum PoE output power: 125 W
8 × 10/100/1000M adaptive electrical ports, 2 × 1000M/2.5G/5G adaptive electrical ports, 2 × 1/10G SFP+ ports, fixed single AC power supply; electrical ports 3–10 support PoE/PoE+; maximum PoE output power: 125 W
16 × 10/100/1000M adaptive electrical ports, 2 × 1000M/2.5G/5G adaptive electrical ports, 2 × 1/10G SFP+ ports, fixed single AC power supply; electrical ports 11-18 support PoE/PoE+; maximum PoE output power: 125 W
432 Gbps/4.32 Tbps
78 Mpps/126 Mpps
51 Mpps/126 Mpps
51 Mpps/126 Mpps
84 Mpps/126 Mpps
92 Mpps/126 Mpps
75 Mpps/126 Mpps
75 Mpps/126 Mpps
84 Mpps/126 Mpps
92 Mpps/126 Mpps
In compliance with IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W)
Scheduled power-on/off of PoE ports
Electrical ports 1–8 support PoE/PoE+ and the maximum PoE output power is 125 W.
Electrical ports 9–16 comply with IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W).
MAC address table
Static MAC addresses
The following items are supported:
4094 IEEE 802.1Q VLANs
MAC-based VLAN
Protocol-based VLAN
L2 ring network technology
In compliance with the G.8032 international standard ring network protocol ERPS, switching time ≤ 50 ms, well compatible with other products that support this protocol
Link aggregation
Cross-VSU AP
Common service ports and aggregate ports can be used as the source and destination ports of SPAN.
One-to-one mirroring, one-to-many mirroring, many-to-one mirroring, RSPAN, ERSPAN
The following are supported:
Static black hole routing, RIP, RIPng, OSPF, and OSPFv3
MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type)
IPv6 ACLs
SP, WRR, DRR, SP+WFQ, SP+WRR, SP+DRR, RED/WRED queue scheduling mechanisms
Security features
Password protection
SSH and SSH V2.0
CPP, NFPP
EEE
APD port sleeping
EEE in compliance with IEEE 802.3az: When EEE is enabled, power consumption of ports is significantly reduced.
Management features
IoT MQTT
Syslog/Debug, NTP/SNTP
SNMP, CLI (telnet/console), RMON, SSH, syslog/debug, NTP/SNTP, FTP, TFTP, Web, RLDP
Size
(W × D × H) (mm)
200 × 170 × 55
200 × 170 × 43.6
200 × 170 × 55
210 × 235 × 55
210 × 235 × 55
210 × 235 × 55
210 × 235 × 55
210 × 250 × 55
210 × 250 × 55
Maximum voltage range: 180 V to 264 V
Frequency: 50 Hz to 60 Hz
Operating temperature: 0°C to 45°C
Storage temperature: –40°C to 70°C
Operating humidity: 5% to 95% RH
4 × 10/100/1000M adaptive electrical ports, 1 × 1G SFP port, fixed single AC power supply; electrical ports 1–4 support PoE/PoE+; maximum PoE output power: 45 W
8 × 10/100/1000M adaptive electrical ports, 1 × 1G SFP port, fixed single AC power supply
8 × 10/100/1000M adaptive electrical ports, 1 × 1G SFP port, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W
