As an industry-leading ICT infrastructure and industry solution provider, Ruijie offers customers a wide variety of high-density and low-power 10G optical modules. They are applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs).
The XG-SFP-SR-MM850 is aligned to IEEE 10GBASE-SR optical specifications and supports a link length of up to 300 meters over a multimode fiber (MMF) with an LC connector. It adopts the SFP+ form factor and operates at a wavelength of 850 nm. The transceiver conforms to IEEE 802.3ae, SFF-8431, SFP+ Multisource Agreement (MSA), and RoHS standards.
XG-SFP-ZR-SM1550 |
XG-SFP-LR10-SM1270-BIDI-I |
XG-SFP-LR10-SM1330-BIDI-I |
Data rate |
10.3125 Gbps |
Form factor |
SFP+ |
Connector type |
Duplex LC |
Duplex LC |
Duplex LC |
Duplex LC |
BIDI LC |
BIDI LC |
Cable type |
MMF |
SMF |
SMF |
SMF |
SMF |
SMF |
Fiber end face finish type |
Ultra Physical Contact (UPC) |
Transmitter type |
VCSEL |
DFB |
DFB |
DFB |
DFB |
DFB |
Receiver type |
PIN |
Reach |
300 m (984.25 ft.) |
10 km (32,808.40 ft.) |
40 km (131,233.60 ft.) |
80 km (262,467.19 ft.) |
10km (32,808.40.13 ft.) |
Bit error ratio (BER) |
1.00E-12 |
Data diagnosis-capable (DDM/DOM) |
Yes |
Power consumption |
≤ 1.5 W |
Transmitter Optical Parameters |
Wavelength |
850 nm |
1310 nm |
1550 nm |
1550 nm |
1270 nm TX 1330 nm RX |
1330 nm TX 1270 nm RX |
Max. transmit power (AVG) |
–1 dBm |
0.5 dBm |
4 dBm |
4 dBm |
0.5 dBm |
0.5 dBm |
Min. transmit power (AVG) |
–7.3 dBm |
–8.2 dBm |
–4.7 dBm |
0 dBm |
–8.2 dBm |
–8.2 dBm |
Min. extinction ratio |
≥ 3.0 dB |
≥ 3.5 dB |
≥ 3 dB |
≥ 8.5 dB |
≥ 3.5 dB |
≥ 3.5 dB |
Receiver Optical Parameters |
Receive sensitivity (OMA) |
< –11.1 dBm |
< –12.6 dBm |
< –14.1 dBm |
< –24 dBm |
< –14.4 dBm |
< –14.4 dBm |
Overload optical power (AVG) |
–1 dBm |
0.5 dBm |
–1 dBm |
–7 dBm |
0.5 dBm |
0.5 dBm |
0°C to 70°C (32°F to 158°F) |
10% RH to 90% RH |
10% RH to 90% RH |
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.) |
35 g (0.08 lbs.) |
Data rate |
10.3125 Gbps |
Form factor |
SFP+ |
Connector type |
SFP+ to SFP+ |
Yes |
Length |
1 m (3.28 ft.) |
3 m (9.84 ft.) |
5 m (16.40 ft.) |
Module type |
Active |
10G SR module, SFP+ form factor, LC, 300 m (984.25 ft.) over MMF |
10G LR module, SFP+ form factor, LC, 10 km ((32,808.40 ft.) over SMF |
10G ER module, SFP+ form factor, LC, 40 km (131,233.60 ft.) over SMF |
XG-SFP-ZR-SM1550 |
10G ZR module, SFP+ form factor, LC, 80 km (262,467.19 ft.) over SMF |
10G LR module, SFP+ form factor, BIDI LC, 10 km (32,808.40.13 ft.) over SMF |
