XG-SFP-ER-SM1550 10GBASE-ER SFP+ 1550-nm 40-km DOM Duplex LC SMF Optical Transceiver Module
Applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection
  • Max. power consumption 1.5 W
  • Hot pluggable SFP+ MSA compliant
  • Digital optical monitoring capability for strong diagnostic capabilities
  • Compliant with IEEE 802.3z Gigabit Ethernet
  • Class 1 Laser safety and RoHS compliant
As an industry-leading ICT infrastructure and industry solution provider, Ruijie offers customers a wide variety of high-density and low-power 10G optical modules. They are applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs).
The XG-SFP-ER-SM1550 is aligned to IEEE 10GBASE-ER optical specifications and supports a link length of up to 40 kilometers over an SMF with an LC connector. It adopts the SFP+ form factor and operates at a wavelength of 1550 nm. The transceiver conforms to IEEE 802.3ae, SFF-8431, SFP+ MSA, and RoHS standards.
Optical Module Specifications
Data rate
10.3125 Gbps
Form factor
SFP+
Connector type
Duplex LC
Duplex LC
Duplex LC
Duplex LC
BIDI LC
BIDI LC
Cable type
MMF
SMF
SMF
SMF
SMF
SMF
Fiber end face finish type
Ultra Physical Contact (UPC)
Transmitter type
VCSEL
DFB
DFB
DFB
DFB
DFB
Receiver type
PIN
Reach
300 m (984.25 ft.)
10 km (32,808.40 ft.)
40 km (131,233.60 ft.)
80 km (262,467.19 ft.)
10km (32,808.40.13 ft.)
Bit error ratio (BER)
1.00E-12
Data diagnosis-capable (DDM/DOM)
Power consumption
1.5 W
Transmitter Optical Parameters
Wavelength
850 nm
1310 nm
1550 nm
1550 nm
1270 nm TX
1330 nm RX
1330 nm TX
1270 nm RX
Max. transmit power (AVG)
1 dBm
0.5 dBm
4 dBm
4 dBm
0.5 dBm
0.5 dBm
Min. transmit power (AVG)
7.3 dBm
8.2 dBm
4.7 dBm
0 dBm
8.2 dBm
8.2 dBm
Min. extinction ratio
3.0 dB
3.5 dB
3 dB
8.5 dB
3.5 dB
3.5 dB
Receiver Optical Parameters
Receive sensitivity (OMA)
< –11.1 dBm
< –12.6 dBm
< –14.1 dBm
< –24 dBm
< –14.4 dBm
< –14.4 dBm
Overload optical power (AVG)
–1 dBm
0.5 dBm
–1 dBm
–7 dBm
0.5 dBm
0.5 dBm
0°C to 70°C (32°F to 158°F)
10% RH to 90% RH
10% RH to 90% RH
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.)
35 g (0.08 lbs.)
Cable Specifications
Data rate
10.3125 Gbps
Form factor
SFP+
Connector type
SFP+ to SFP+
Length
1 m (3.28 ft.)
3 m (9.84 ft.)
5 m (16.40 ft.)
Module type
Active
10G SR module, SFP+ form factor, LC, 300 m (984.25 ft.) over MMF
10G LR module, SFP+ form factor, LC, 10 km ((32,808.40 ft.) over SMF
10G ER module, SFP+ form factor, LC, 40 km (131,233.60 ft.) over SMF
10G ZR module, SFP+ form factor, LC, 80 km (262,467.19 ft.) over SMF
10G LR module, SFP+ form factor, BIDI LC, 10 km (32,808.40.13 ft.) over SMF
