2.5G-SFP-LX03-SM1310-BIDI-I 2.5G BiDi SFP 1310nm-TX/1550nm-RX 3-km DOM Simplex LC SMF Transceiver Module
Applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection.
  • Max. power consumption 1 W.
  • Saving half fiber by using only one fiber for transmiting and receiving.
  • Hot pluggable SFP MSA compliant.
  • Digital optical monitoring capability for strong diagnostic capabilities.
  • Compliant with IEEE 802.3z Gigabit Ethernet.
  • Class 1 Laser safety and RoHS compliant.
As an industry-leading ICT infrastructure and industry solution provider, Ruijie offers customers a wide variety of high-density and low-power 2.5G optical modules. They are applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs).
The 2.5G-SFP-LX03-SM1310-BIDI-I is aligned to IEEE 2.5GBASE-LX optical specifications and supports a link length of up to 3 kilometers over a single mode fiber (SMF) with a BIDI LC connector. It adopts the SFP form factor and operates at a wavelength of 1310 nm. The transceiver conforms to SFF-8431, SFF-8472, and RoHS standards.
Optical Module Specifications
2.5G-SFP-LX03-SM1311-BIDI-I
2.5G-SFP-LX03-SM1551-BIDI-I
Data rate
3.125 Gbps
Form factor
SFP
Connector type
BIDI LC
Cable type
SMF
Fiber end face finish type
Ultra Physical Contact (UPC)
Transmitter type
FB
DFB
Receiver type
PIN
Reach
3 km (9,842.52 ft.)
Bit error ratio (BER)
1.00E-12
Data diagnosis-capable (DDM/DOM)
Power consumption
1 W
Transmitter Optical Parameters
Wavelength
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
Max. transmit power (AVG)
–3 dBm
Min. transmit power (AVG)
–9 dBm
Min. extinction ratio
6.5 dB
Receiver Optical Parameters
Receive sensitivity (OMA)
< –16 dBm
Overload optical power (AVG)
–3 dBm
–40ºC to +85ºC (–40ºF to +185ºF)
10% RH to 90% RH
10% RH to 90% RH
(W x D x H)
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.51 in. x 0.33 in.)
35 g (0.08 lbs.)
2.5G LX module, SFP form factor, BIDI LC, 3 km (9,842.52 ft.) over SMF
