Applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs)
As an industry-leading ICT infrastructure and industry solution provider, Ruijie offers customers a wide variety of high-density and low-power 1G optical modules. They are applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs).
MINI-GBIC-ZX80-SM1550 Module
The MINI-GBIC-ZX80-SM1550 is aligned to IEEE 1000BASE-ZX optical specifications and supports a link length of up to 80 kilometers over an SMF with an LC connector. It adopts the SFP form factor and operates at a wavelength of 1550 nm. The transceiver conforms to the IEEE 802.3, SFF-8472, SFF-8431, SFF-8432, SFP+ MSA, and RoHS standards.
MINI-GBIC-GT |
Data rate |
1.25 Gbps |
1000base-X to 1000base-T |
Form factor |
SFP |
Connector type |
Duplex LC |
Duplex LC |
Duplex LC |
Duplex LC |
RJ45 |
Cable type |
MMF |
SMF |
SMF |
SMF |
Cat 5e/6/6a |
Fiber end face finish type |
Ultra Physical Contact (UPC) |
N/A |
Transmitter type |
VCSEL |
DFB |
DFB |
DFB |
N/A |
Receiver type |
PIN |
N/A |
Reach |
550 m (1,804.46 ft.) |
10 km (32,808.40 ft.) |
40 km (131,233.60 ft.) |
80 km (262,467.19 ft.) |
100 m (328.08 ft.) |
Bit error ratio (BER) |
1.00E-12 |
N/A |
Data diagnosis-capable (DDM/DOM) |
Yes |
No |
Power consumption |
≤ 1.5 W |
Transmitter Optical Parameters |
Wavelength (nm) |
850 |
1310 |
1310 |
1550 |
N/A |
Max. transmit power (AVG) |
0 dBm |
–3 dBm |
0 dBm |
5 dBm |
N/A |
Min. transmit power (AVG) |
–9.5 dBm |
–11 dBm |
–5 dBm |
0 dBm |
N/A |
Min. extinction ratio |
≥ 9 dB |
N/A |
Receiver Optical Parameters |
Receive sensitivity (OMA) |
< –17 dBm |
< –19 dBm |
< –23 dBm |
< –27 dBm |
N/A |
Overload optical power (AVG) |
0 dBm |
–3 dBm |
–3 dBm |
–3 dBm |
N/A |
0°C to 70°C (32°F to 158°F) |
10% RH to 90% RH |
10% RH to 90% RH |
56.5 mm x 13.5 mm x 8.5mm (2.22 in. x 0.53 in. x 0.33 in.) |
68 mm x 14 mm x 8.5 mm (2.68 in. x 0.55 in. x 0.33 in.) |
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.) |
35 g (0.08 lbs.) |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LX03-SM1310-BIDI-I |
GE-SFP-LX03-SM1550-BIDI-I |
Data rate |
1.25 Gbps |
Form factor |
SFP |
Connector type |
BIDI LC |
Cable type |
SMF |
Transmitter type |
DFB |
DFB |
FP |
DFB |
FP |
DFB |
Receiver type |
PIN |
Reach |
20 km (65,616.80 ft.) |
3 km (9,842.52 ft.) |
1.00E-12 |
Yes |
Power consumption |
≤ 1.5 W |
Wavelength |
1310 nm TX 1550 nm RX |
1550 nm TX 1310 nm RX |
0 dBm |
–3 dBm |
–5 dBm |
–9 dBm |
≥ 9 dB |
< –23 dBm |
< –20 dBm |
< –22 dBm |
–3 dBm |
5% RH to 95% RH |
5% RH to 95% RH |
35 g (0.08 lbs.) |
1G SR module, SFP form factor, LC, 550 m (1,804.46 ft.) over MMF |
1G LX module, SFP form factor, LC, 10 km (32,808.40 ft.) over SMF |
1G LH module, SFP form factor, LC, 40 km (131,233.60 ft.) over SMF |
1G ZX module, SFP form factor, LC, 80 km (262,467.19 ft.) over SMF |
1G LH module, SFP form factor, BIDI LC, 40 km (32,808.40 ft.) over SMF |
1G BIDI module-TX1310/RX1550-industrial class, SFP form factor, BIDI LC, 3 km (9,842.52 ft.) |
1G BIDI module-TX1550/RX1310-industrial class, SFP form factor, BIDI LC, 3 km (9,842.52 ft.) |
