GE-SFP-LX03-SM1310-BIDI-I 1000BASE-LX SFP 1310nm-TX/1550nm-RX 3-km DDM Simplex LC SMF Transceiver Module
Applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs)
  • Max. power consumption 1.5 W
  • Saving half fiber by using only one fiber for transmiting and receiving
  • Hot pluggable SFP MSA compliant
  • Digital optical monitoring capability for strong diagnostic capabilities
  • Compliant with IEEE 802.3z Gigabit Ethernet
  • Class 1 Laser safety and RoHS compliant
As an industry-leading ICT infrastructure and industry solution provider, Ruijie offers customers a wide variety of high-density and low-power 1G optical modules. They are applicable to data center and campus networks, enabling cost-effective, efficient, and high-speed interconnection among switches, routers, servers, and network interface controllers (NICs).
GE-SFP-LX03-SM1310-BIDI-I Module
The GE-SFP-LX03-SM1310-BIDI-I is aligned to IEEE 1000BASE-LX optical specifications and supports a link length of up to 3 kilometers over an SMF with a BIDI LC connector. It adopts the SFP form factor and operates at a wavelength of 1310 nm. The transceiver conforms to IEEE 802.3, SFF-8472, SFF-8431, SFF-8432, SFP+ MSA, and RoHS standards.
MINI-GBIC Series Module Specifications
MINI-GBIC-GT
Data rate
1.25 Gbps
1000base-X to 1000base-T
Form factor
SFP
Connector type
Duplex LC
Duplex LC
Duplex LC
Duplex LC
RJ45
Cable type
MMF
SMF
SMF
SMF
Cat 5e/6/6a
Fiber end face finish type
Ultra Physical Contact (UPC)
Transmitter type
VCSEL
DFB
DFB
DFB
Receiver type
PIN
Reach
550 m (1,804.46 ft.)
10 km (32,808.40 ft.)
40 km (131,233.60 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
Bit error ratio (BER)
1.00E-12
Data diagnosis-capable (DDM/DOM)
Power consumption
≤ 1.5 W
Transmitter Optical Parameters
Wavelength (nm)
850
1310
1310
1550
Max. transmit power (AVG)
0 dBm
–3 dBm
0 dBm
5 dBm
Min. transmit power (AVG)
–9.5 dBm
–11 dBm
–5 dBm
0 dBm
Min. extinction ratio
≥ 9 dB
Receiver Optical Parameters
Receive sensitivity (OMA)
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
Overload optical power (AVG)
0 dBm
–3 dBm
–3 dBm
–3 dBm
0°C to 70°C (32°F to 158°F)
10% RH to 90% RH
10% RH to 90% RH
56.5 mm x 13.5 mm x 8.5mm (2.22 in. x 0.53 in. x 0.33 in.)
68 mm x 14 mm x 8.5 mm (2.68 in. x 0.55 in. x 0.33 in.)
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.)
35 g (0.08 lbs.)
Single-Fiber SFP Series Module (BIDI) Specifications
Data rate
1.25 Gbps
Form factor
SFP
Connector type
BIDI LC
Cable type
SMF
Transmitter type
DFB
DFB
FP
DFB
FP
DFB
Receiver type
PIN
Reach
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
1.00E-12
Power consumption
≤ 1.5 W
Wavelength
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
0 dBm
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
1G SR module, SFP form factor, LC, 550 m (1,804.46 ft.) over MMF
1G LX module, SFP form factor, LC, 10 km (32,808.40 ft.) over SMF
1G LH module, SFP form factor, LC, 40 km (131,233.60 ft.) over SMF
1G ZX module, SFP form factor, LC, 80 km (262,467.19 ft.) over SMF
1G LH module, SFP form factor, BIDI LC, 40 km (32,808.40 ft.) over SMF
1G BIDI module-TX1310/RX1550-industrial class, SFP form factor, BIDI LC, 3 km (9,842.52 ft.)
1G BIDI module-TX1550/RX1310-industrial class, SFP form factor, BIDI LC, 3 km (9,842.52 ft.)
