Supporting hybrid cables in Ruijie Networks Power over Fiber (PoF) Solution, and suitable for various scenarios with rich features, including metropolitan area networks (MANs), campus networks, and data centers
The connection distance between a PoF switch and an SOE indoor switch can reach up to 1.5 km.
A single port can deliver a maximum power of 100 W, while the entire switch supports a maximum power supply of 6 kW.
Hybrid cables are used to provide secure power supplies from the main equipment room, eliminating the need for local high-voltage power sources.
Hareware Specifications |
S7805C |
S7808C |
S7810C |
RG-S7808C-V2 |
Power module |
2 |
2 |
4 |
4 |
Supervisor module slot |
2 |
2 |
2 |
2 |
Line card slot |
3 |
6 |
8 |
6 |
Switch fabric module slot |
Built-in |
2 (integrated with supervisor modules) |
4 (2 are integrated with supervisor modules) |
Packet forwarding rate |
4,500 Mpps |
9,000 Mpps |
12,000 Mpps |
System switching capacity |
6 Tbps |
12 Tbps |
16 Tbps |
MAC address |
● Number of global MAC addresses EB card: 64,000 DA card: 96,000 (default) and 288,000 (max.) FA card: 80,000 FB card: 96,000 ● Number of static MAC addresses EB card: 4,000 DA card: 10,000 FA card: 4,000 ● FB card: 40,000 |
ARP table |
EB card: 10,000 (default and recommended) DA card: underlay: 75,000; overlay: 0 (default and recommended) FA card: underlay: 30,000; overlay: 0 FB card: underlay: 50,000; overlay: 0 (default and recommended) |
EB card: 12,000 (default and recommended, shared with IPv6 routes) DA card: 12,000 (default and recommended, shared with IPv6 routes) FA card: 12,000 (default and recommended, shared with IPv6 routes) FB card: 134,000 (default and recommended, shared with IPv6 routes) |
EB card: 8,000 DA card: 16,000 FA card: 8,000 FB card: 16,000 |
EB card: 6,000 (shared with IPv4 routes) DA card: 6,000 (shared with IPv4 routes) FA card: 6,000 (shared with IPv4 routes) FB card: 50,000 (shared with IPv4 routes) |
EB card: 4,000 DA card: 8,000 FA card: 4,000 FB card: 8,000 |
● Ingress EB card: 3,500 DA card: 8,000 FA card: 5,000 FB card: 4,500 ● Egress EB card: 1,000 DA card: 1,000 FA card: 1,000 ● FB card: 2,000 |
Number of VSU members |
2 |
2 |
2 |
2 |
442 mm x 451 mm x 175 mm (17.40 in. x 17.76 in. x 6.89 in., 4 RU) |
442 mm x 465mm x 441.7 mm (17.40 in. x 18.31 in. x 17.39 in., 10 RU) |
442.5 mm x 560 mm x 442 mm (17.42 in. x 22.05 in. x 17.40 in., 10 RU) |
32.35 kg (71.32 lbs) |
35.6 kg (78.48 lbs) |
43.6 kg (96.12 lbs) |
● Supervisor module M7805C-CM/M7805C-CM II: 1.5 GHz quad-core processor ● Service module EA/EB card: 1.0 GHz quad-core processor DA/F card: 1.5 GHz quad-core processor |
● Supervisor module M7800C-CM: 1.0 GHz quad-core processor M7808C-CM II: 1.5 GHz quad-core processor ● Service module EA/EB card: 1.0 GHz quad-core processor DA/F card: 1.5 GHz quad-core processor |
● Supervisor module M7808C-CM II: 1.5 GHz quad-core processor ● Service module EB card: 1.0 GHz quad-core processor DA/F card: 1.5 GHz quad-core processor ● Switch fabric module M7810C-FE-D I/M7810C-FE-F I: 1.5 GHz quad-core processor |
● Supervisor module M7808C-CM II: 1.5 GHz quad-core processor ● Service module EA/EB card: 1.0 GHz quad-core processor ● DA/F card: 1.5 GHz quad-core processor |
Storage |
Flash memory M7805C-CM/M7805C-CM II: 1 GB EA card: 512 MB EB card: 512 MB DA/F card: 8 GB SDRAM M7805C-CM/M7805C-CM II: DDRIII 4 GB EA card: DDR3 1 GB EB card: DDRIII 1 GB DA card: DDR4 1 GB F card: DDR4 2 GB |
Flash memory Supervisor module: M7800C-CM/M7808C-CM II: 8 GB Service module: EA card: 512 MB EB card: 512 MB DA/F card: 8 GB SDRAM Supervisor module: M7800C-CM: DDR3 4 GB M7808C-CM II: DDR4 4 GB Service module: EB card: DDR3 1 GB DA card: DDR4 1 GB F card: DDR4 2 GB |
Flash memory Supervisor module: M7810C-CM/M7810C-CM-F: 8 GB Service module: EB card: 512 MB DA/F card: 8 GB Switch fabric module: M7810C-FE-D I: 8 GB M7810C-FE-F I: 8 GB SDRAM Supervisor module: M7810C-CM/M7810C-CM-F: DDR4 4 GB Service module: EB card: DDR3 1 GB DA card: DDR4 1 GB F card: DDR4 2 GB Switch fabric module: M7810C-FE-D I card: DDR4 1 GB M7810C-FE-F I: DDR4 2 GB |
Flash memory Supervisor module: M7808C-CM II: 8 GB Service module: EA card: 512 MB EB card: 512 MB DA/F card: 8 GB SDRAM Supervisor module: M7808C-CM II: DDR4 4 GB Service module: EB card: DDR3 1 GB DA card: DDR4 1 GB F card: DDR4 2 GB |
Power and Consumption |
Chassis RG-S7805C: < 80 W Supervisor module: M7805C-CM II: < 21 W Service module: M7800C-24SFP/12GT4XS-EB: < 85 W M7800C-36GT12SFP4XS-EB: < 80 W M7800C-48GT4XS-EB: < 70 W M7800C-48SFP4XS-EB: < 101 W M7800C-24GT24SFP4XS-EB: < 88 W M7800C-32XS4QXS-DA: < 210 W M7800C-24XT4QXS-DA: < 245 W M7800C-48GT-FA: < 75 W M7800C-48SFP-FA: < 95 W M7800C-48XS-FB: < 160 W M7800C-4CQ-FB: < 120 W M7800C-8CQ-FB: < 130 W |
Chassis RG-S7808C: < 176 W Supervisor module: M7808C-CM II: < 50 W Service module: M7800C-24SFP/12GT4XS-EB: < 85 W M7800C-36GT12SFP4XS-EB: < 80 W M7800C-48GT4XS-EB: < 70 W M7800C-48SFP4XS-EB: < 101 W M7800C-24GT24SFP4XS-EB: < 88 W M7800C-32XS4QXS-DA: < 210 W M7800C-24XT4QXS-DA: < 245 W M7800C-48GT-FA: < 75 W M7800C-48SFP-FA: < 95 W M7800C-48XS-FB: < 160 W M7800C-4CQ-FB: < 120 W M7800C-8CQ-FB: < 130 W |
Chassis RG-S7810C: < 432 W Supervisor module: M7810C-CM: < 50 W M7810C-CM-F: < 110 W Service module: M7800C-24SFP/12GT4XS-EB: < 85 W M7800C-36GT12SFP4XS-EB: < 80 W M7800C-48GT4XS-EB: < 70 W M7800C-48SFP4XS-EB: < 101 W M7800C-24GT24SFP4XS-EB: < 88 W M7800C-32XS4QXS-DA: < 210 W M7800C-24XT4QXS-DA: < 245 W M7800C-48GT-FA: < 75 W M7800C-48SFP-FA: < 95 W M7800C-48XS-FB: < 160 W M7800C-4CQ-FB: < 120 W M7800C-8CQ-FB: < 130 W Switch fabric module: M7810C-FE-D I: < 50 W M7810C-FE-F I: < 105 W |
Chassis RG-S7808C-V2: < 176 W Supervisor module: M7808C-CM II: < 50 W Service module: M7800C-24SFP/12GT4XS-EB: < 85 W M7800C-36GT12SFP4XS-EB: < 80 W M7800C-48GT4XS-EB: < 70 W M7800C-48SFP4XS-EB: < 101 W M7800C-24GT24SFP4XS-EB: < 88 W M7800C-32XS4QXS-DA: < 210 W M7800C-24XT4QXS-DA: < 245 W M7800C-48GT-FA: < 75 W M7800C-48SFP-FA: < 95 W M7800C-48XS-FB: < 160 W M7800C-4CQ-FB: < 120 W M7800C-8CQ-FB: < 130 W |
Maximum output power |
● RG-PA300I-F: 300 W ● RG-PA460I-F: 460 W |
● RG-PA600I-F: 600 W ● RG-PA1600I-F: 90 V to 180 V: 12,00 W 180 V to 264 V: 1,600 W ● RG-PD600I-F: 600 W ● RG-PA800IF: 800 W |
● RG-PA600I: 600 W ● RG-PA1600I: 90 V to 180 V: 1,200 W 180 V to 264 V: 1,600 W ● RG-PD600I: 600 W ● RG-PD1600I: 1,400 W |
● RG-PA600I-F: 600 W ● RG-PA1600I-F: 90 V to 180 V: 12,00 W 180 V to 264 V: 1,600 W ● RG-PD600I: 600 W |
> 200,000 hours |
Primary Airflow |
● Supervisor module Right-to-left airflow ● Service module Right-to-rear airflow ● System power module Built-in fan modules drawing air outward Front-to-rear airflow |
● Supervisor module /Service module Right-to-rear airflow ● System power module Front-to-rear airflow |
● Line card Side-to-rear airflow ● Supervisor module/FE Front-to-rear airflow |
0°C to 50°C (32°F to 122°F) |
Operating altitude |
–500 m to +5,000 m (–1640.42 ft. to +16404.20 ft.) |
Operating noise |
55.9 dB at the temperature of 35°C (95°F) 73.4 dB at the temperature of 50°C (122°F) |
Interface surge protection |
All electrical ports support 4 kV surge protection in common mode or 1 kV surge protection in differential mode. |
Power port: 6 kV Telecom port: 4 kV (MGMT port) |
RG-S7800C Series |
Feature |
Ethernet switching |
802.3az EEE |
Super-VLAN and private VLAN |
IP service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
Manual tunnel, automatic tunnel, and ISATAP tunnel for IPv6 |
GRE tunnel |
IP routing |
OSPFv2 and OSPFv3 |
GR |
IPv4/IPv6 IS-IS |
BGP4 and BGP4+ |
EVPN |
IPv4/IPv6 VRF |
Policy-based routing (PBR) |
IPv4 and IPv6 ECMP |
IGMP v1/v2/v3 |
IGMP snooping v1/v2/v3 |
IGMP proxy |
IGMP fast leave |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 and IPv6 |
MLDv1 and MLDv2 |
Multicast static routing |
MLD v1/v2 snooping |
PIM-SMv6 |
MPLS |
MPLS IPv6 |
MPLS L3VPN |
MPLS 6VPE |
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) |
ACL80 and IPv6 ACL |
Port traffic identification |
Port-based rate limiting |
802.1p |
CAR |
Eight queues on each port |
AAA |
RADIUS authorization and accounting |
TACACS+ |
Portal authentication, RADIUS, and TACACS+ login authentication |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMP |
Port security |
DAI |
SAVI |
ARP spoofing prevention |
CPU Protect Policy (CPP) and NFPP |
Various attack defense functions, including NFPP and ARP anti-attack |
uRPF Login authentication and password security Unknown multicast packets are not sent to the CPU, and unknown unicast packets can be suppressed. |
Rapid Ethernet Uplink Protection (REUP) |
VRRP for the super-VLAN |
BFD |
1+1 redundancy for supervisor modules and fan modules, and N+M redundancy for power modules |
Hot swapping of components |
Hot patch and online installation of patches |
GR for OSPF/IS-IS/BGP |
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP |
SNTP |
FTP, TFTP, and Xmodem |
SNMP v1/v2c/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
CWMP |
Web-based NMS |
Console/Telnet/SSH2.0 CLI configuration Fault alarms and auto-recovery System operation logging |
VXLAN |
Layer 2 and Layer 3 VXLAN gateways |
S7805C |
RG-S7805C switch, which can accommodate three line cards and two supervisor modules |
S7808C |
RG-S7808C switch, which can accommodate six line cards and two supervisor modules |
S7808C-V2 |
RG-S7808C-V2 switch, which can accommodate six line cards and two supervisor modules (only M7808C-CM II supported) |
S7810C |
RG-S7810C switch, which can accommodate eight service cards, two supervisor modules, and two switch fabric modules |
M7805C-CM |
S7805C high-performance 1st-generation supervisor module |
M7805C-CM II |
S7805C high-performance 2nd-generation supervisor module |
M7800C-CM |
S7808C high-performance 1st-generation supervisor module |
M7808C-CM II |
S7808C high-performance 2nd-generation supervisor module |
M7810C-CM |
S7810C high-performance 1st-generation supervisor module |
M7810C-CM-F |
S7810C high-performance 2nd-generation supervisor module |
RG-PA300I-F |
S7805C power module (AC, 300 W, 10 A) |
RG-PA460I-F |
S7805C power module (available for redundancy, AC, 460 W, 10 A) |
RG-PA600I-F |
S7808C power module (available for redundancy, AC, 600 W, 10 A) |
RG-PA1600I-F |
S7808C power module (available for redundancy, AC, 1600 W, 16 A) |
RG-PA1600I-PL |
Universal PoE power module (available for redundancy, AC, 1600 W, 16 A) |
RG-PA3000I-PL |
Universal PoE power module (available for redundancy, AC, 3000 W, 16 A) |
RG-PD600I-F |
S7808C power module (available for redundancy, DC, 600 W, –48 V) |
RG-PA600I |
S7810C power module (available for redundancy, AC, 600 W, 10 A) |
RG-PD600I |
S7810C power module (available for redundancy, DC, 600 W, 20 A) |
RG-PA1600I |
S7810C power module (available for redundancy, AC, 1600 W, 16 A) |
RG-PD1600I |
S7810C power module (available for redundancy, DC, 1400 W, 50 A) |
M08-FAN |
S7808C fan: Each M08-FAN tray consists of two fan modules and one fan monitoring card. It blows air to the outside for convection. This is a default configuration for the switches. |
M7800C-48DP |
External power supply card of the RG-S7808C-V2, 48 power output ports per card, and a maximum of 100 W power per port |
M7810C-FE-D I |
RG-S7810C switch fabric module I |
M7810C-FE-F I |
RG-S7810C 2nd-generation switch fabric module |
M7800C-32XS-XA |
32 x 10GE optical ports (SFP+ and LC) |
M7800C-24GT8SFP8XS-XA |
24 x GE electrical ports (RJ45) + 8 x GE optical ports (SFP, LC) + 8 x 10GE optical ports (SFP+ and LC) |
M7800C-48GT4XS-XA |
48 x GE electrical ports (RJ45) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-48SFP4XS-XA |
48 x GE optical ports (SFP, LC) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-52XS-XB |
52 x 10GE optical ports (SFP+ and LC) |
M7800C-12CQ-XB |
12-port 100G/40G optical port (QSFP+ and MPO/LC) |
M7800C-48XS-FB |
48 x 10GE optical ports (SFP+ and LC) |
M7800C-8CQ-FB |
8 x 100G Ethernet optical ports (QSFP28 and LC) |
M7800C-48GT-FA |
48 x GE electrical ports (RJ45) |
M7800C-48SFP-FA |
48 x GE optical ports (SFP+ and LC) |
M7800C-16SFP8XS-EA |
16 x GE optical ports (SFP and LC) + 8 x 10GE optical ports (SFP+ and LC) |
M7800C-24SFP/12GT4XS-EA |
24 x GE optical ports (SFP and LC) + 12 x GE electrical combo ports (RJ45) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-24GT24SFP4XS-EA |
24 x GE electrical ports (RJ45) + 24 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-36GT12SFP4XS-EA |
36 x GE electrical ports (RJ45) + 12 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-48SFP4XS-EA |
48 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-48GT4XS-EA |
M7800C-32XS4QS-DA |
32 x 10GE optical ports (SFP+ and LC) + 4 x 40G Ethernet optical ports (QSFP+ and MPO) |
M7800C-24XT4QXS-DA |
24 x 10GE electrical ports (RJ45) + 4 x 40G Ethernet optical ports (QSFP+ and MPO) |
M7800C-24GT24SFP4XS-EB |
24 × GE electrical ports (RJ45) + 24 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC) |
M7800C-24SFP/12GT4XS-EB |
M7800C-48GT4XS-EB |
M7800C-48SFP4XS-EB |
M7800C-36GT12SFP4XS-EB |
36 x GE electrical ports (RJ45) + 12 x GE optical ports (SFP and LC) + 4 × 10GE optical ports (SFP+ and LC) |
*M7800C-24QXS-DA |
24-port 40G Ethernet optical interface board (OSFP+ and MPO) |
*RG-WALL 1600-B-F |
High-performance firewall module |
*RG-M7800C-WS-F |
Wireless control module |
