RG-S7805C |
RG-S7808C |
Module Slots |
5(2 for control engines) |
8 (2 for control engines) |
Modular Power Slots |
2(for system power) |
6 (4 for system power; 2 for PoE power) |
Switching Capacity |
6Tbps |
12Tbps |
Forwarding Rate |
4500Mpps |
9000Mpps |
Max. Number of 10GE Ports |
Up to 24 |
Up to 48 |
Non Support |
Support |
ARP Table |
10K(EB) 30K(FA) 75K(DA) |
MAC Table |
64K(EB) 80k(FA) 96K(DA) |
Routing Entries |
Up to 10K |
Up to 10K |
Multicast Entries (IPv4/IPv6) |
Up to 8K/4K |
Up to 8K/4K |
ACL Entries |
Up to 3,500 |
Up to 3,500 |
VLAN |
Up to 4K |
Up to 4K |
QinQ |
Basic QinQ, Flexible QinQ |
Link Aggregation |
AP, LACP |
AP, LACP |
Port Mirroring |
Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring, SPAN, RSPAN, VLAN mirroring |
Spanning Tree Protocols |
Support STP, RSTP and MSTP |
DHCP |
Support DHCP relay, DHCP snooping, DHCP server, DHCP client |
Multiple Spanning Tree (MST) Instances |
64 (not include default 0) |
Up to 2,048 |
Up to 2,048 |
Virtual Routing and Forwarding (VRF) Instances |
Up to 1,000 |
Up to 1,000 |
VSU (Virtual Switch Unit) |
Up to 2 stack members |
VSD (Virtual Switch Device) |
Up to 4 VSD units |
Up to 4 VSD units |
L2 Features |
Jumbo Frame, 802.1Q, STP, RSTP, MSTP, Super VLAN, GVRP, QinQ, Flexible QinQ, LLDP, ERPS (G.8032),MAC Based VLAN,Voice VLAN,RLDP |
Jumbo Frame, 802.1Q, STP, RSTP, MSTP, Super VLAN, GVRP, QinQ, Flexible QinQ, LLDP, ERPS (G.8032) |
Layer 2 Protocols |
IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, Jumbo Frame (9Kbytes), IEEE802.1ad (QinQ and flexible QinQ), GVRP |
Layer 3 Features |
ARP, IPv4/v6, PBR v4/v6 |
Layer 3 Protocols (IPv4) |
Ping, Traceroute, Equal-Cost Multi-Path Routing (ECMP) |
IPv4 Features |
Static routing, RIP, OSPF, BGP4, ISIS, VRRP, Equal-cost routing, Policy-based routing, GRE tunnel |
IPv6 Features |
Static routing OSPFv3, BGP4+, IS-ISv6, MLD, VRRPv3, Equal-cost routing,Policy-based routing, Manual tunnel, Auto tunnel, ISATAP tunnel, GRE tunnel |
Static routing OSPFv3, BGP4+, IS-ISv6, MLD, VRRPv3, Equal-cost routing Policy-based routing, Manual tunnel, Auto tunnel, ISATAP tunnel, GRE tunnel |
Basic IPv6 Protocols |
DNS client v6, DHCP relay v6, DHCP v6 server, Telnet v6, TFTP client v6, FTP v6, NTP client v6, NTP server v6 |
Routing Protocols |
RIP, RIPng, OSPFv2/v3, BGP4, BGP4+, IS-ISv4/v6, Routing Policy |
IPv6 Tunnel Features |
6over4 Manual Tunnel, 6to4 Auto Tunnel, Manual Tunnel, Auto Tunnel, ISATAP Tunnel, IPv4 over IPv6 Tunnel, IPv6 over IPv4 Tunnel, GRE Tunnel(4 over 6), GRE Tunnel(6 over 4) |
IGMP v1/v2/v3, IGMP snooping, IGMP proxy, Multicast routing protocols (PIM-DM, PIM-SM, PIM-SSM), MLD, Multicast static routing |
G.8032 |
Support |
Support |
ACE Capacity |
Up to 3,500 |
Up to 3,500 |
ACL |
Standard/Extended/Expert ACL; ACL 80; IPv6 ACL |
QoS |
802.1p, Queue scheduling mechanisms (SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR), RED/WRED, Input/output port-based speed limit |
IPv6 ACL |
Support |
Support |
Control engine, power supply and fan: 1+1 redundancy; Hot-swappable components; Hot patch and online patch upgrade; GR for OSPF/IS-IS/BGP; BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
EEE Format |
Support EEE (802.3az) |
NFPP (Network Foundation Protection Policy), CPP (CPU Protection), DAI, Port Security, IP Source Guard, 802.1x, Portal authentication, RADIUS and TACACS+ user login authentication, uRPF, Account privileges and password security policy, Unknown multicasts are not delivered to CPU and support unknown unicasts suppression, Support SSHv2 to provide a secure and encrypted channel for user login |
Manageability |
Console/AUX Modem/Telnet/SSH2.0 command line configuration; FTP, TFTP, Xmodem file upload/download management; SNMP V1/V2c/V3; RMON; NTP clock; Fault alarm and self-recovery; System log; sFlow |
Hot Patch |
Support |
Support |
Smart Temperature Control |
Fan speed auto-adjustment; Fan malfunction alerts; Fan status check |
Smart Power Supply |
Support power control and management |
Other Protocols |
DHCP client, DHCP relay, DHCP server, ARP proxy, Syslog |
442mmx 451mmx 175mm,4U |
442mm ×595mm ×439mm, 10U |
Rack Height |
4RU |
10RU |
12.42kg (total weight of empty chassis and fans) |
32.35kg (total weight of empty chassis and fans) |
312K hours |
312K hours |
Safety Standards |
IEC 60950-1, EN 60950-1 |
Emission Standards |
EN 300 386, EN 55022/55032, EN 61000-3-2, EN 61000-3-3, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11 |
Power Supply |
RG-PA300I-F:90-290Vac and 1 92-290Vdc ~300W |
RG-PA1600I-F:90-180V~1200W;180-264V~ 1600W RG-PA600I-F:90-180V~ 600W;180-264V~ 600W RG-PA1600I-PL:90-175V~1000W;176-264V~1600W RG-PA3000I-PL:90-175V~1200W;176-209V~2500W;210-264V~ :3000W |
Power Consumption |
<80W |
<176W |
PoE Power Consumption |
Non Support |
<800W |
Temperature |
Operating temperature: 0ºC to 50ºC |
Storage temperature: -40ºC to 70ºC |
Humidity |
Operating humidity: 10% to 90% RH (non-condensing) |
Storage humidity: 5% to 95% RH |
Operating Altitude |
3,000m to 5,000m |
3,000m to 4,000m |
