RG-S6150-48VS8CQ-X
and Network Connectivity
Guaranteed Data Transmission
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
Basic Features
Ports and Modules
24 x 10G/25G SFP28 ports
8 x 40G/100G QSFP28 ports
4 fan modules
2 hot-swappable power supply modules
48 x 10G/25G SFP28 ports
4 fan modules
Management Ports
One MGMT port, one console port, and one USB port (compliant with the USB 2.0 standard)
2.8 Tbps
4 Tbps
1024Mpps/1680Mpps
1024Mpps/2800Mpps
Power Consumption (Full Load)
270 W
300 W
Product Features
4K 802.1Q VLAN
LACP (802.3ad)
STP, RSTP, MSTP
IPv6 DHCP server
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
IPv6 Basic Protocols
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, Path MTU Discovery
BGP4, BGP4+
MCE
IGMP v1, IGMPv2, IGMPv3, IGMP proxy
PIM-DM, PIM-SM, PIM-SSM
MLD snooping, MLD
PIM for IPv6
ACL &
The following flexible and diversified hardware ACLs are supported:
MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type)
Expert-level ACLs (hardware ACLs based on flexible combinations of the Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time)
IPv6 ACLs
SP, DRR, SP+DRR, RED/WRED queue scheduling mechanisms
Security Features
Port- and MAC-based 802.1x authentication
SSH
CPP, NFPP
Management Features
SNMP, CLI (Telnet/Console), RMON, SSH, Syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for v6, Traceroute v6
sFlow, which utilizes the random sampling technology to conduct flow information sampling on the traffic of a switch.
MACC-based management
Hot swapping of power modules
Physical Features
Frequency: 50/60 Hz
Rated voltage: 240 V DC
Maximum voltage range: 192 V DC to 288 V DC
3+1 redundancy, at least three fan modules are required for the system.
Temperature Alarming
Storage temperature: –40°C to 70°C (–40°F to 158°F)
Operating humidity: 10% to 90% (non-condensing)
Storage humidity: 5% to 95%
RG-S6150-24VS8CQ-X
4 fan modules
2 power supply module slots
RG-S6150-48VS8CQ-X
4 fan modules
RG-PA550I II-F
550 W AC power supply module
1000BASE-GT mini GBIC module
VG-SFP-SR-MM1310
100G-AOC-1M
