RG-S6120-48XMG4VS2QXS-UP-H Next-generation Multi-GE Switches
Diverse access rates: 10 Gbps/5 Gbps/2.5 Gbps/1 Gbps/100 Mbps
Multiple power modes: PoE/PoE+/PoE++
4 x 25GE SFP28 ports and 2 x 40GE QSFP28 ports for uplink, enabling flexible networking and high-performance campus networks
  • 48 x 10GE/5GE/2.5GE/GE/100M Base-T Ethernet ports for access, 4 x 25GE SFP28 ports and 2 x 40GE QSFP28 ports for uplink, meeting high-bandwidth campus network demands
Multi-GE Access
Recent years have witnessed the rapid evolution of the Ethernet interface standards from 10BASE-T and 100BASE-T to 1000BASE-T (IEEE 802.3ab) that is widely applied to devices covering PCs and APs. However, as the Wi-Fi 6 technology has been introduced, APs can delivers an uplink rate of 10 Gbps, posing an increasing challenge to GE network devices. The RG-S6100 provides 100M/1000M/2.5G/5G Base-T and 100M/1000M/2.5G/5G/10G Base-T Ethernet ports in auto-negotiation mode which can better adapt to Wi-Fi 6 APs.
High-Power PoE Power Supply
In the previous scenarios of PoE remote power supply, only PoE (IEEE 802.3af) and PoE+ (IEEE 802.3at) standards are available. If the power exceeds 30 W, PoE cannot be used for power supply. Instead, power cables must be deployed for mains power supply, and even EHV power deployment is required. This imposes tremendous challenges on deployment costs and period, maintenance, and security during the deployment. In compliance with the IEEE802.3bt standard, the RG-S6100 adopts high-power PoE power supply and achieves a maximum PoE output of 90 W through a single Ethernet port to significantly improve user experience.
The hardware of the RG-S6100 supports IPv4/IPv6 dual stacks and multilayer line-rate switching to differentiate and process IPv4 and IPv6 packets. The RG-S6100 also provides flexible IPv6 network communication solutions for users to perform network planning or maintain network status quo based on various IPv6 network demands. The RG-S6100 supports a wide range of IPv4 routing protocols, covering IPv4 static routing, RIP, OSPFv2, IS-ISv4, and BGP4. You can select appropriate routing protocols to flexibly build networks based on various network environments. Meanwhile, the RG-S6100 also supports abundant IPv6 routing protocols, including IPv6 static routing, RIPng, OSPFv3, IS-ISv6, and BGP4+. A routing protocol can be selected flexibly to upgrade the live network to an IPv6 network or establish a new IPv6 network.
Virtual Switching Unit
The RG-S6100 supports Virtual Switch Unit (VSU). VSU enables multiple physical devices to be connected through aggregate links and virtualized into one logical device. The devices use the same IP address, Telnet process, and CLI for management, and support automatic version check and automatic configuration. In this context, a network administrator only manages one logical device, improving working efficiency and experience.
Fault recovery within milliseconds: A VSU connects to peripheral devices through aggregate links. If a fault occurs on one device or member link in the VSU, data and services can be switched to another member link within 30 ms.
The hardware-based IPv6 ACL can easily control the access of IPv6 users at the network edge even if there are IPv6 users on an IPv4 network. The switch allows IPv4 and IPv6 users to coexist and can control access permissions of IPv6 users, for example, restricting access to sensitive resources on the network.
The RG-S6100 provides a unique hardware CPU protection mechanism: CPU Protection Policy (CPP). The CPP enables the switch to classify data traffic sent to the CPU, process the traffic by queue priority, and apply the rate limit to traffic as required. The CPP fully protects the CPU from being occupied by unauthorized traffic, malicious attacks, and resource consumption, which ensures the security of the CPU and the switch.
DHCP snooping enables the RG-S6100 to receive DHCP Response messages only from trusted ports and prevent spoofing from unauthorized DHCP servers. With DHCP snooping, the switch dynamically monitors ARP packets, checks users’ IP addresses, and discards unauthorized packets that do not match binding entries. This effectively prevents ARP spoofing and source IP address spoofing.
The switch also supports the device access control through source IP-based Telnet, which can prevent unauthorized users and hackers from maliciously attacking and controlling the switch, and enhance the network management security of the switch.
Through the Secure Shell (SSH) and Simple Network Management Protocol version 3 (SNMPv3), the switch can encrypt management information in Telnet and SNMP processes. This ensures information security of management devices and prevents hackers from attacking and controlling the devices.
The switch rejects unauthorized network access and enables authorized network access by employing multi-element binding, port security, time-based ACL, and data stream-based rate limiting. The RG-S6100 can strictly control user access to enterprise networks and campus networks and restrict the communication of unauthorized users.
The RG-S6100 supports the Network Foundation Protection Policy (NFPP) to enhance its security. By isolating attack sources, the policy can protect the processor and channel bandwidth resources of the switch. This ensures normal packet forwarding and protocol status.
The RG-S6100 supports Spanning Tree Protocols (IEEE 802.1D, IEEE 802.1w, and IEEE 802.1s) to achieve fast convergence, improve the fault tolerance capability, and ensure stable network operation and link load balancing. The RG-S6100 effectively utilizes network channels to improve the usage of aggregate links.
The Virtual Router Redundancy Protocol (VRRP) effectively facilitates network stability for the switch.
With the Rapid Link Detection Protocol (RLDP), the RG-S6100 can quickly detect the link connectivity and unidirectional optical fiber links. Through port loop detection, the switch can prevent network failures caused by the loops that occurs in the scenario where an unauthorized port is connected to hubs.
When STP is disabled, the Rapid Ethernet Uplink Protection Protocol (REUP) can still provide basic link redundancy and millisecond-level fault recovery faster than STP.
The RG-S6100 supports Bidirectional Forwarding Detection (BFD) for upper-level protocols (such as routing protocols), rapidly detecting connectivity of the forwarding path between two routing devices. BFD greatly shortens the convergence time for the upper-level protocols upon link status changes.
The RG-S6100 supports the IPv4 and IPv6 multicast functions as well as multiple multicast protocols, including IGMP snooping, IGMP, Multicast Listener Discovery (MLD), Protocol Independent Multicast (PIM), PIM for IPv6, and Multicast Source Discovery Protocol (MSDP). The switches provide multicast service support for IPv4 networks, IPv6 networks, and IPv4 and IPv6 coexistent networks.
The IGMP source port and source IP address check function supported by the RG-S6100 can effectively eliminate unauthorized multicast sources and enhance the network security.
Sound QoS Policies
The RG-S6100 is capable of classifying and controlling various flows including MAC flows, IP flows, and application flows, to implement fine-grained bandwidth control, forwarding priority, and other flow policies. Furthermore, the switch can provide services based on applications and QoS levels required by different applications.
The Differentiated Services (DiffServ) model supports IEEE 802.1p priorities, IP ToS values, traffic filtering based on Layer 2 to Layer 7 information, Strict Priority (SP), Weighted Round Robin (WRR), and other QoS policies.
Energy-Saving Design
The RG-S6100 adopts the next-generation hardware architecture, and advanced energy-efficient circuit design and components, to reduce energy consumption and noise. RG-S6100 series switches are equipped with variable-speed axial fan modules to intelligently control the fan speed based on the ambient temperature, which reduces the power consumption and noise while ensuring stable operation of the switch.
The RG-S6100 supports SNMP, RMON, Syslog, and USB-based log and configuration backup for routine network diagnosis and maintenance. Administrators can utilize diversified management and maintenance methods, including the CLI, web-based NMS, and Telnet to facilitate device management.
A PoE button is available on the panel of the switch. You can press this button to check both communication status and PoE status of all ports on the switch.
Multi-GE Switch
RG-S6110-24MG4VS-UP
RG-S6110-48MG4VS2QXS-UP
 RG-S6120-24XMG4XS4VS-UP-H
Fixed Service Port
4 x 10GE/25GE SFP28 ports
4 x 10GE/25GE SFP28 ports + 2 x 40GE QSFP28 ports
4 x 1G/10GE SFP+ ports
4 x 10G/25G QSFP28 ports
Module Slot
Built-in power module
Fixed Management Port
1 x MGMT port
1 x MGMT port
1 x MGMT port
1 x MGMT port
System
2.56 Tbps/25.6 Tbps
2.56 Tbps/25.6 Tbps
2.56 Tbps/25.6 Tbps
2.56 Tbps/25.6 Tbps
(Actual)
327 Mpps
625 Mpps
565 Mpps
982Mpps
Typical Power Consumption
Without PoE: < 110 W (Total power consumption of all modules)
Full PoE load: < 370 W (Total power consumption of all modules)
Without PoE: < 200 W (Total power consumption of all modules)
Full PoE load: < 1600 W (Total power consumption of all modules)
Without PoE: < 150 W (Total power consumption of all modules)
Full PoE load: < 1650 W (Total power consumption of all modules)
Power Module Model
RG-PA1000P-F
RG-PA1000P-F
RG-PA1000P-F
Rated Input Voltage
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
Rated current per circuit: 8 A
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
Maximum Input Voltage
PoE-capable Port
Fan Module
3 x hot swappable fan modules
Surge Protection
6 kV
6 kV
6 kV
6 kV
Temperature Monitoring
Temperature alarm
Temperature alarm
Temperature alarm
Temperature alarm
RG-S6110-24MG4VS-UP
4K IEEE 802.1Q VLAN
Super VLAN
Traffic mirroring
Many-to-one mirroring and one-to-many mirroring
Link aggregation mirroring
DHCP Server
DHCP Client
DHCP Snooping
DHCP Relay
IPv6 DHCP Snooping
IPv6 DHCP Client
IPv6 DHCP Relay
IPv6 addressing, ICMPv6, and Path MTU Discovery
IGMP v1/v2/v3 and IGMP proxy
MLD Snooping and MLD
The following flexible and diversified hardware ACLs are supported:
MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type)
Expert ACLs (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time)
SP, WRR, DRR, SP+WRR, SP+DRR, and RED/WRED queue scheduling
Security Features
SSH
BPDU Guard
Management Features
sFlow, using the random sampling technology to conduct flow information sampling on the traffic of a switch
GR for RIP, OSPF, BGP
Follow the steps to order a RG-S6100 multi-GE switch:
Switch and Power Module
RG-S6110-24MG4VS-UP
fixed AC power supply and  fans
48 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation, support PoE/PoE+/PoE++(25-48 ports only support PoE/PoE+)
4 x 10GE/25GE SFP28 + 2 x 40GE QSFP28 ports
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation, support PoE/PoE+/PoE++
4 x 1G/10GE SFP+ ports ,4 x 10G/25G QSFP28 ports
48 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation, support PoE/PoE+/PoE++(25-48 ports only support PoE/PoE+)
GE Optical Module
10GE Optical Module
50 μm/125 μm: 66 m over MMF
2000 MHz·km: 300 m over MMF
25GE Optical Module
40GE Optical Module
