48-Port GE All-Optical Layer 3 Enterprise-Class Core or Aggregation Switch, Four 10G Uplink Ports, RG-S5760C-48SFP4XS-X
176Gbps/656Gbps(including expansion module)
Forwarding rate
131Mpps/488Mpps(including expansion module)
Item
RG-S5760C-24GT8XS-X
RG-S5760C- 24SFP/8GT8XS-X
RG-S5760C-48GT4XS-X
Basic Features
Fixed Ports
24x 10/100/1000BASE-T, 8 x
1G/10G SFP+ ports, 2 power
module slots
24 x Gigabit SFP ports (ports 1-16 are 100M/1000M SFP ports),
8 10/100/1000BASE-T ports (combo), 8 x 1G/10G SFP+ ports, 2 power module slots
48x 10/100/1000BASE-T, 4 x
module slots
1 MGMT port, 1 console port, and 1 USB port, compliant with USB2.0 standard
Expansion Slot
Single expansion slot is reserved to for service modules.
System Switching
Capacity
880 Gbps/7.92 Tbps
Forwarding Rate
426 Mpps/600 Mpps
426 Mpps/600 Mpps
406 Mpps/600 Mpps
64K
24K
Routing Table
Size (IPv4/IPv6)
24K (IPv4/IPv6)
Product Features
The following are supported:
4K 802.1Q VLAN
Port based VLAN Private VLAN Voice VLAN GVRP
Basic QinQ Flexible QinQ
LACP(802.3ad)
Spanning Tree
DHCP Server DHCP Client DHCP Snooping DHCP Relay
IPv6 DHCP Server IPv6 DHCP Snooping IPv6 DHCP Client IPv6 DHCP Relay
128
IPv6 Basic Protocol
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, stateless auto-configuration, and Path MTU Discovery
OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6 BGP4, and BGP4+
Equivalent routing
Policy Based Routing
Packet-based load balancing, and flow-based load balancing MCE
The following are supported: IGMP v1, v2, v3, and IGMP proxy IGMP v1, v2 and v3 Snooping
IGMP filtering, and IGMP fast-leave PIM-DM, PIM-SM, and PIM-SSM
MLD Snooping, and MLD PIM for IPv6
ACL& QoS
The following flexible and diversified hardware ACLs are supported: Standard IP ACLs (IP-based hardware ACL)
MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type) Time-based ACLs
Expert-level ACLs (hardware ACLs based on flexible combinations of Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time)
ACL80 IPv6 ACLs
Port traffic identification Port traffic rate limiting
SP, DRR, SP+DRR, RED/WRED queue scheduling mechanisms
3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses
Port- and MAC-based 802.1x authentication MAB authentication
Portal authentication and Portal 2.0 authentication ARP-check
Gateway ARP spoofing prevention Broadcast storm suppression
Hierarchical management of administrators and password protection RADIUS and TACACS+
AAA for device login management SSH
BPDU Guard
IP Source Guard CPP, and NFPP
Management Features
SNMP, CLI (Telnet/Console), RMON, SSH, Syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for v6, and Traceroute v6
This switch supports sFlow, and samples its traffic information by using the random sampling technology of data flows.
VSU (virtualization technology, which virtualizes multiple devices into one), GR for RIP/OSPF/BGP and other routing protocols, BFD detection, ERPS (G.8032), REUP, RLDP, power supply 1+1 backup, and the hot- swappable function supported on the power supply
Zero
CPE WAN Management Protocol (CWMP(TR069))
Unsupported
Physical Features
Dimensions (W
× D × H)
442 mm × 340 mm × 44 mm
MTBF (hours)
Rated voltage range: 100 V to 240 V Maximum voltage range: 90 V to 264 V Frequency: 50/60 Hz
Rated voltage range: 240 V
Power Consumption (full load)
60 W
77 W
70 W
2 built-in fans
Alarm
Operating temperature: 0oC to 45oC(without an expansion card), 0oC to 40oC (with an expansion card) Storage temperature: -40oC to 70oC
Relative
Operating humidity: 5% to 95%(no condensation) Storage humidity: 5% to 95%
Operating
500m to 5,000m
6kV (Common Mode)
RG-S5760C-24GT8XS-X
24 x 10/100/1000BASE-T, 8 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed)
RG-S5760C-48GT4XS-X
48 x 10/100/1000BASE-T, 4 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed)
RG-S5760C-24SFP/8GT8XS-X
24 x 1000M SFP ports (ports 1-16 are 100M/1000M SFP ports), 8 x 10/100/1000BASE-T ports (combo), 8 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed)
150W AC power module
1000BASE-SX, SFP Transceiver, SM (850nm, 500m, LC).
1000BASE-LX, SFP Transceiver, SM (1310nm, 10km, LC)
1000BASE-LH, SFP Transceiver, SM (1310nm, 40km, LC)
1000BASE-ZX50, SFP Transceiver, SM (1550nm, 50km, LC)
1000BASE-ZX80, SFP Transceiver, SM (1550nm, 80km, LC)
1000BASE-ZX100, SFP Transceiver, SM (1550nm, 100km, LC).
10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 3 Meters
10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 5 Meters
