Item |
RG-S5760C-24GT8XS-X |
RG-S5760C- 24SFP/8GT8XS-X |
RG-S5760C-48GT4XS-X |
Basic Features |
Fixed Ports |
24x 10/100/1000BASE-T, 8 x 1G/10G SFP+ ports, 2 power module slots |
24 x Gigabit SFP ports (ports 1-16 are 100M/1000M SFP ports), 8 10/100/1000BASE-T ports (combo), 8 x 1G/10G SFP+ ports, 2 power module slots |
48x 10/100/1000BASE-T, 4 x 1G/10G SFP+ ports, 2 power module slots |
Management Port |
1 MGMT port, 1 console port, and 1 USB port, compliant with USB2.0 standard |
Expansion Slot |
Single expansion slot is reserved to for service modules. |
System Switching |
880 Gbps/7.92 Tbps |
Forwarding Rate |
426 Mpps/600 Mpps |
426 Mpps/600 Mpps |
406Mpps/600Mpps |
MAC Address |
64K |
ARP Table |
24K |
24K (IPv4/IPv6) |
Product Features |
VLAN |
The following are supported: 4K 802.1Q VLAN Port based VLAN Private VLAN Voice VLAN GVRP |
QinQ |
Basic QinQ Flexible QinQ |
Link Aggregation |
LACP(802.3ad) |
Spanning Tree |
The following are supported: STP, RSTP, and MSTP |
DHCP |
The following are supported: DHCP Server DHCP Client DHCP Snooping DHCP Relay IPv6 DHCP Server IPv6 DHCP Snooping IPv6 DHCP Client IPv6 DHCP Relay |
Multiple Spanning Tree Protocol (MSTP) Instances |
64 |
128 |
IPv6 Basic Protocol |
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, stateless auto-configuration, and Path MTU Discovery |
IP Routing |
The following are supported: Static routing RIP and RIPng OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6 BGP4, and BGP4+ Equivalent routing Policy Based Routing Packet-based load balancing, and flow-based load balancing MCE |
The following are supported: IGMP v1, v2, v3, and IGMP proxy IGMP v1, v2 and v3 Snooping IGMP filtering, and IGMP fast-leave PIM-DM, PIM-SM, and PIM-SSM MLD Snooping, and MLD PIM for IPv6 |
MPLS |
MPLS L3VPN |
ACL& QoS |
ACL |
The following flexible and diversified hardware ACLs are supported: Standard IP ACLs (IP-based hardware ACL) Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port IDs) MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type) Time-based ACLs Expert-level ACLs (hardware ACLs based on flexible combinations of Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time) ACL80 IPv6 ACLs |
QoS |
The following are supported: Port traffic identification Port traffic rate limiting 802.1p/DSCP/ToS traffic classification Eight priority queues per port SP, DRR, SP+DRR, RED/WRED queue scheduling mechanisms |
Security Features |
The following are supported: 3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC-based 802.1x authentication MAB authentication Portal authentication and Portal 2.0 authentication ARP-check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection RADIUS and TACACS+ |
Security Features |
AAA for device login management SSH BPDU Guard IP Source Guard CPP, and NFPP Port protection |
Management Features |
SNMP, CLI (Telnet/Console), RMON, SSH, Syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for v6, and Traceroute v6 This switch supports sFlow, and samples its traffic information by using the random sampling technology of data flows. |
High Reliability |
The following are supported: VSU (virtualization technology, which virtualizes multiple devices into one), GR for RIP/OSPF/BGP and other routing protocols, BFD detection, ERPS (G.8032), REUP, RLDP, power supply 1+1 backup, and the hot- swappable function supported on the power supply |
Zero Configuration |
CPE WAN Management Protocol (CWMP(TR069)) |
Unsupported |
Physical Features |
Dimensions (W × D × H) |
442 mm × 340 mm × 44 mm |
Rack Height |
1RU |
MTBF (hours) |
>200K |
Power Supply |
AC input: Rated voltage range: 100 V to 240 V Maximum voltage range: 90 V to 264 V Frequency: 50/60 Hz HVDC input: Rated voltage range: 240 V Maximum voltage range: 192 V to 288 V |
Power Consumption (full load) |
60 W |
77 W |
70 W |
Fan |
2 built-in fans Fan speed regulating and alarm function |
Temperature Alarm |
Supported |
Temperature |
Operating temperature: 0oC to 45oC(without an expansion card), 0oC to 40oC (with an expansion card) Storage temperature: -40oC to 70oC |
Relative Humidity |
Operating humidity: 5% to 95%(no condensation) Storage humidity: 5% to 95% |
Operating Altitude |
500m to 5,000m |
Lightening Protection on Communication Port |
6kV (Common Mode) |
Lightning Protection on Power Port |
Common Mode 6KV/Differential Mode 6KV |
24 x 10/100/1000BASE-T, 8 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed) |
48 x 10/100/1000BASE-T, 4 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed) |
RG-S5760C-24SFP/8GT8XS-X |
24 x 1000M SFP ports (ports 1-16 are 100M/1000M SFP ports), 8 x 10/100/1000BASE-T ports (combo), 8 x 1G/10G SFP+ ports, reserved expansion slots, 2 built-in fixed fans, 2 power module slots (at least 1 RG-PA150IB-F power modules needed) |
RG-PA150IB-F |
150W AC power module |
1000BASE-TX, SFP Transceiver (100m) |
1000BASE-SX, SFP Transceiver, SM (850nm, 500m, LC). |
1000BASE-LX, SFP Transceiver, SM (1310nm, 10km, LC) |
1000BASE-LH, SFP Transceiver, SM (1310nm, 40km, LC) |
MINI-GBIC-ZX50-SM1550 |
1000BASE-ZX50, SFP Transceiver, SM (1550nm, 50km, LC) |
1000BASE-ZX80, SFP Transceiver, SM (1550nm, 80km, LC) |
MINI-GBIC-ZX100-SM1550 |
1000BASE-ZX100, SFP Transceiver, SM (1550nm, 100km, LC). |
10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC) |
10GBASE-SR, SFP+ Transceiver (1310nm, 10km, LC) |
10GBASE-SR, SFP+ Transceiver (1550nm, 40km, LC) |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 1 Meter |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 3 Meters |
10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 5 Meters |
