Home> Products> Switches> Core/Aggregation Switches>
RG-N18012
Newton 12-Slot Chassis Campus Core Switch
More+
Cloud Network-oriented
New-Generation Core Switch
TOLLY Group
Virtual Switch Unit 3.0 (VSU)
Virtual Switch Device (VSD)
Core Concepts
Solution Components
●Hardware Switching Devices:
●SDN Controller RG-IONC
○MPLS L3 VPN service
Hardware
RG-N18007
RG-N18012
Module slots
7 (2 for supervisor modules)
12 (2 for supervisor modules); 4 independent SFU also supported
325.8 Tbps
780 Tbps
60,000 Mpps
120,000 Mpps
RG-N18007
RG-N18012
(W × D × H)
442 mm × 598 mm × 352.8 mm
442 mm × 725 mm × 708.4 mm
Rack size
8U
16U
RG-N18007
RG-N18012
RG-PA1600I: 90 V to 180 V    Power: 1200 W; 180 V to 264 V   Power: 1600 W
RG-PD1600I: -40 V to -75 V    Power: 1400 W
RG-PD600I: -40 V to -75 V    Power: 600 W
RG-PA1600I-PL: 90 V to 175 V    Power: 1000 W; 176 V to 264 V   Power: 600 W
RG-PA3000I-PL: 90 V to 175 V    Power: 200 W; 176 V to 209 V   Power: 2500 W
210 V to 264 V    Power: 3000 W
RG-N18007
RG-N18012
Storage temperature: –40°C to 70 °C
-500 m to 5000 m
Port lightening protection
6 KV
Software
Software
RG-N18007
RG-N18012
Data center integrated network features
Enhanced Ethernet features (DCB)
802.1Qbb: Priority-based Flow Control (PFC)
802.1Qaz: Enhanced Transmission Selection (ETS and DCBX)
802.1Qau: Congestion Notification (CN/QCN)
Unified fabric feature: FCoE
Virtual Switching Unit (VSU), virtual bandwidth ≥2.56 Tbps
* Virtual Switch Device (VSD)
* Vertical virtualization
Network virtualization
TRILL transparent switching network
L2GRE
* VXLAN L2 bridge
* VXLAN L3 gateway
Edge Virtual Bridging (EVB)
OpenFlow 1.3.
L2 features
4096 802.1Q VLAN
STP, RSTP, MSTP
Super VLAN
QinQ, flexible QinQ and QinQ termination
 DHCP Relay
 DHCP Snooping
 DHCP Server (at least 2700 users/second)
 DHCP Client
Behavior control
URL audit
User locating
Central authentication
Concurrence of 9W IPv4 and IPv6 double stack users with an authentication capacity of 1200 terminals per second
802.1x/Portal/MAC/IPoE authentication methods
L2 Portal and L3 Portal access authentication
Flow-based charging, flow control, refined management
Gateway authentication
IPv4 features
VRRP, VRRP+
Policy-based routing
GRE tunnel
IPv6 features
Static routing, RIPng, OSPFv3, BGP4+, IS-ISv6, etc.
VRRPv6
Manual tunnel, automatic tunnel, ISATAP tunnel, and GRE tunnel
IGMP snooping
MLD
MPLS forwarding.
Cross-domain OPTION A/B/C modes
L3 MPLS VPN
VPLS/VPWS
Up to 2000
Standard, extended, and expert-level ACLs.
802.1P
SP, WRR, DRR, SP+WRR, SP+DRR, and other queue scheduling mechanisms
RED/WRED
Port-based rate limit
*HQoS
Many-to-one mirroring, one-to-many mirroring, and flow-based mirroring.
SPAN, RSPAN, Dynamic MAC address mirroring and VLAN mirroring
Independent switch fabric modules and independent supervisor modules to implement thorough separation of the forwarding plane from the control plane.
1+1 redundancy for supervisor engines
N+M redundancy for power supply and fans
Passive backplane design, eliminating single point of failures.
IP FRR
ISSU
GR for OSPF/IS-IS/BGP/
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/ MPLS/static routing.
DAI, ARP Check, Port security, and IP source guard
SSHv2, providing encrypted security channels for user login.
ITU-T Y.1731
EEE (802.3az)
SNMP V1/V2c/V3
RMON
NTP clock
sFLOW traffic flow analysis
Hardware supports DCMI (Data Center Manageability Interface) to remotely power on, power off, reset, and monitor device status
RG-N18007
RG-N18012
Supervisor Module
M18007-CM II
RG-N18007 2nd-generation supervisor module
M18007-CM II Lite
RG-N18007 2nd-generation Lite supervisor module
M18012-CM II
RG-N18012 2nd-generation supervisor module
M18012-CM
RG-N18012 supervisor module
Power Module
RG-PA600I
RG-PD600I
RG-PA1600I
RG-PD1600I
Generic power module of RG-N18000 series (redundancy, DC, 1400 W, 50 A)
RG-PA1600I-PL
Generic PoE module of RG-N18000 series (redundancy, AC, 1600 W, 16 A)
RG-PA3000I-PL
Generic PoE module of RG-N18000 series (redundancy, AC, 3000 W, 16 A)
Switch Fabric Module
M18012-FE-D I
Line Card
M18000-44SFP4XS-ED
44 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC)
M18000-44SFP4XS-EF
M18000-48GT-ED
48 x GE electrical ports (RJ45)
M18000-48GT-EF
M18000-48GT-P-ED
48 x GE PoE electrical ports (RJ45)
M18000-24GT20SFP4XS-ED
24 x GE electrical ports (RJ45) + 20 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC)
M18000-08XS-ED
8 x 10GE optical ports (SFP+ and LC)
M18000-16XS2QXS-ED
16 x 10GE optical ports (SFP+ and LC) + 2 x 40GE optical ports (QSFP+ and MPO)
M18000-08XS-EF
M18000-48XS-DC
48 x 10GE optical ports (SFP+ and LC)
M18000-24XS4QXS-DC
24 x 10GE optical ports (SFP+ and LC) + 4 x 40GE optical ports (QSFP+ and MPO)
M18000-12QXS-DC
12 x 40GE optical ports (QSFP+ and MPO)
M18000-12CQ-EH
12 x 100GE optical ports (QSFP28)
*M18000-16CQ-EH
16 x 100GE optical ports (QSFP28)
*M18000-36QXS-CB
36 x 40GE optical ports (QSFP+ and MPO)
*M18000-36CQ-CB
36 x 100GE optical ports (QSFP28)
*M18000-48CQ-CB
48 x 100GE optical ports (QSFP28)
*M18000-16XT-CB
16 x 10GE electrical ports (RJ45)
Multi-service Module
RG-WALL 1600-B-ED
Firewall service module
RG-M18000-WS-ED
Wireless controller module
M18000-MSC-ED
Gateway authentication and charging module
*M18000-MSC-ED (IPS)
IPS service module
*M18000-MSC-ED (AC)
App control gateway module
*M18000-MSC-ED (LB)
Load balancing module
*M18000-MSC-ED (IPFIX)
Flow analysis module
*M18000-MSC-ED (VPN)
SSL VPN module
Next-Generation Multi-Process
Modular OS
Rich Data Center Features
VSU Multiple-to-One
VSD One-to-Multiple
TOLLY Group
Supported VSU and VSD
Only One Switch to Manage
Comparison of Port Bandwidths
Frame Size (bytes)
Latency Comparison
64-byte 0.532 0.650
128-byte 0.545 0.651
512-byte 0.588 0.666
1518-byte 0.586 0.665
4096-byte 0.586 0.665
9216-byte 0.586 0.665
Port Buffer Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
The test results show that:
Up to 512K MAC entries
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
control modules switch
Uplink Failure 30ms
Main and Backup
Main switch failure 11ms
Backup switch failure 11ms
Uplink failover: 35 ms
Stability
Tolly Certified Features
OpenFlow 1.3 Main Feature
Stateless Process Restart
Hot Process Patching
N+1 Fabric Module Redundancy
Hot Swappable Fabric Module
Power Consumption Analysis
  Without Any
Line Card
Load All
Modules - 0%
Traffic
Load All
Modules - 30%
Traffic
Load All
Modules - 100%
Traffic
Difference
between 100%
traffic and without
any line card
Average Apparent
Power per line
card with 100%
traffic
Average Apparent
Power per 40GbE
port with 100%
traffic
  Apparent Power
Without Any
Line Card
1.456VA
Load All
Modules - 0%
Traffic
2.573VA
Load All
Modules - 30%
Traffic
2.742VA
Load All
Modules - 100%
Traffic
3.108VA
Difference
between 100%
traffic and without
any line car
1.652VA
Average Apparent
Power per line
card with 100%
traffic
206.5VA
Average Apparent
Power per 40GbE
port with 100%
traffic
8.6VA
TOLLY Group
Frame Size (bytes)
Latency Comparison
64-byte 0.532 0.650
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
128,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Entry Comparison
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
Capacity 3
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port 2
MAC Table
Capacity 3
512,000
Capacity 3
170,000
FIB Table
Capacity 4
IPv6 Neighbor
Cache Table
Capacity 3
28,000
802.1x
Authentication
Capacity 5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Uplink Failure 30ms
Main and Backup
Stability
  Without Any
Line Card
Load All
Modules - 0%
Traffic
Load All
Modules - 30%
Traffic
Load All
Modules - 100%
Traffic
Difference
between 100%
traffic and without
any line card
Average Apparent
Power per line
card with 100%
traffic
Average Apparent
Power per 40GbE
port with 100%
traffic
  Apparent Power
Without Any
Line Card
1.456VA
Load All
Modules - 0%
Traffic
2.573VA
Load All
Modules - 30%
Traffic
2.742VA
Load All
Modules - 100%
Traffic
3.108VA
Difference
between 100%
traffic and without
any line car
1.652VA
Average Apparent
Power per line
card with 100%
traffic
206.5VA
Average Apparent
Power per 40GbE
port with 100%
traffic
8.6VA
Product Datasheet
Installation Guide
Release Note
Windows
