RG-CS88-08 Ruijie Cloud Managed 10 RU Modular High-Performance Core Switch
Dual-Boot Backup
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
1+1 Fan Redundancy
RG-CS88-08
Supervisor module slots
Line card slots
9.6 Tbps
Forwarding rate
7200 Mpps
442 x 465 x 441.7 mm (17.40 x 18.31 x 17.39 in)
35.6 kg (78.48 lbs)
RG-PA600I-F:  90 V to 180 V    Power: 600 W; 180 V to 264 V    Power: 600 W
RG-PA1600I-F: 90 V to 180 V    Power: 1200 W; 180 V to 264 V   Power: 1600 W
27°C: 55.9 dB
45°C: 73.4 dB
Temperature Alarm
RG-CS88 Series
MPLS 6VPE
MPLS IPv6
Manual tunnel, automatic tunnel, ISATAP tunnel, and GRE tunnel
Policy-based routing
DAI, port security, and IP source guard
802.1x
packets can be suppressed.
Hot patch function and online installation of patches
Green energy saving
RG-CS88-08
CM88-CM
2.Power Modules and Fans
RG-PA600I-F
RG-PA1600I-F
M08-FAN
3.Line Cards
Commercial-grade line cards
CM88-48XS-H
CM88-8CQ-H
CM88-48GT-H
CM88-48SFP-H
