RG-CS86-24XMG4XS4VS-UPD: 24-Port Ruijie Cloud-Managed Multi-GE Switch, Full 1/2.5/5/10GE Access with PoE++
Diverse access rates: 10 Gbps/5 Gbps/2.5 Gbps/1 Gbps/100 Mbps
Multiple power modes: PoE/PoE+/PoE++
4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, enabling flexible networking and high-performance campus networks
  • 24 x 10GE/5GE/2.5GE/GE/100M Base-T Ethernet ports for access, 4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, meeting high-bandwidth campus network demands
24 x service ports: 10 Gbps/5 Gbps/2.5 Gbps/1 Gbps/100 Mbps access, 4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, enabling flexible networking High-power PoE++, offering up to 90 W output and adapting to services in Wi-Fi 6E and Wi-Fi 7 eras
Multi-GE Switch
RG-CS86-24MG4VS-UP
RG-CS86-48MG4VS2QXS-UPD
Fixed Service Port
4 x 10GE/25GE SFP28 ports
4 x 10GE/25GE SFP28 ports + 2 x 40GE QSFP28 ports
4 x 1G/10GE SFP+ ports
4 x 10G/25G QSFP28 ports
Fan modules
2 fixed fans
3 modular fans
3 modular fans
Power modules
1 Built-in power module
Fixed Management Port
1 x MGMT port
1 x MGMT port
1 x MGMT port
440 Gbps/2.56Tbps
840 Gbps/2.56Tbps
760Gbps/2.56Tbps
(Actual)
327 Mpps
625 Mpps
565 Mpps
MAC Table Capacity
32,768
IPv4 Unicast Routes
IPv4 Multicast Routes
IPv6 Unicast Routes
IPv6 Multicast Routes
In: 2,500
Out:1,000
442 × 220 × 43.6 (17.40 × 29.92 × 6.89 in.) , 1 RU
3.65 kg (8.82 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
Typical Power Consumption
Without PoE: < 110 W (Total power consumption of all modules)
Full PoE load: < 370 W (Total power consumption of all modules)
Without PoE: < 200 W (Total power consumption of all modules)
Full PoE load: < 1600 W (Total power consumption of all modules)
Without PoE: < 150 W (Total power consumption of all modules)
Full PoE load: < 1650 W (Total power consumption of all modules)
Power Module Model
RG-PA1000P-F
RG-PA1000P-F
Rated Input Voltage
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
Rated current per circuit: 8 A
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
PoE-capable Port
Surge Protection
6 kV
6 kV
6 kV
Temperature Monitoring
Temperature alarm
Temperature alarm
Temperature alarm
RG-CS86-24MG4VS-UP
GR for RIP, OSPF, BGP
Switch and Power Module
RG-CS86-24MG4VS-UP
fixed AC power supply and fan
4 x 10GE/25GE SFP28 + 2 x 40GE QSFP28 ports, support PoE/PoE+/PoE++(25-48 ports only support PoE/PoE+)
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation, 4 x 1G/10GE SFP+ ports ,4 x 10G/25G QSFP28 ports,support PoE/PoE+/PoE++
 GE Optical Module
 10GE Optical Module
50 μm/125 μm: 66 m over MMF
2000 MHz·km: 300 m over MMF
 25GE Optical Module
 40GE Optical Module
