RG-CS85-24GT8XS-D
RG-CS85-24SFP/8GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
Fan modules
Power modules
Expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
426Mpps/600Mpps
406Mpps/600Mpps
System Switching capacity
880Gbps
64000
64000
64000
64000
64000
24000
24000
24000
24000
24000
Routing table size (IPv4)
24K
24K
24K
24K
24K
Routing table size (IPv6)
14K
14K
14K
14K
14K
In: 7000
Out:1500
440 mm x 340 mm x 44 mm
442 mm x 420 mm x 43.6 mm
4.4 kg
5.5 kg
5.3 kg
Dual-core CPU, 1.2 GHz
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 2 GB
Flash memory: 4 GB
SDRAM: 2 GB
< 110 W (non-PoE)
< 1590 W (PoE full load)
< 150 W
RG-PA150I-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150I-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150I-F: 150 W
RG-PA150IB-F: 150 W
176 V AC to 290 V AC, 1000 W
RG-PA150I-F: 150 W
AC:
100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
200 V to 240 V
DC: 48 V to 60 V
AC:
100 V to 240 V DC: 48 V to 60 V
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V
AC: 90 V to 264 V
LVDC: 36 V to 75 V
AC: 90 V to 264 V
LVDC: 36 V to 75 V
AC: 176 V to 264 V
DC: 38 V to 75 V
AC: 90 V to 264 V
DC: 36 V to 75 V
≥ 1,051,000 hours
≥ 823,000 hours
≥ 963,000 hours
≥ 832,000 hours
≥ 788,000 hours
0°C to 45°C (32°F to 115°F)
45°C: 56.2 dB
45°C: 57.1 dB
45°C: 57.9 dB
27°C: 50 dB
45°C: 65 dB
27°C: 53 dB
45°C: 68 dB
Power port: 6 kV/6 kV
Software S
pecifications
RG-CS85 Series
  • Select a switch and expansion modules based on port requirements.
  • Select power supply modules.
RG-CS85-24GT8XS-D
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-D
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-HPD
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48SFP4XS-D
CM85-4XS2CQ
150 W AC power supply module
