RG-S5760C-48GT4XS-HP-X Switches - 1
RG-S5760C-48GT4XS-HP-X Switches - 2
RG-S5760C-48GT4XS-HP-X Switches - 3
RG-S5760C-48GT4XS-HP-X Switches - 4
RG-S5760C-48GT4XS-HP-X Switches - 5
RG-S5760C-48GT4XS-HP-X Switches - 6
RG-S5760C-48GT4XS-HP-X Switches - 7
RG-S5760C-48GT4XS-HP-X Switches - 8
RG-S5760C-48GT4XS-HP-X Switches - 9
RG-S5760C-48GT4XS-HP-X Switches - 10
RG-S5760C-48GT4XS-HP-X Switches - 11
RG-S5760C-48GT4XS-HP-X Switches - 12
RG-S5760C-48GT4XS-HP-X 48-Port GE Electrical Layer 3 Enterprise-Class PoE Core or Aggregation Switch, Four 10G Uplink Ports
  • Rich port types, 48 x 1000 Mbps Ethernet ports, PoE/PoE+ supported, and4 x 10G optical ports for uplink
Aggregation switch for small and medium-sized campus networks, with four 10G uplink optical ports for data transmission; 48 x 1000 Mbps Ethernet ports with auto-negotiation, PoE/PoE+ supported, providing high-speed network experience for short-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-S5760C-24SFP8GT8XS-X
RG-S5760C-48SFP4XS-X
Two built-in fan modules
Three pluggable fan modules
Two pluggable fan modules
Two power modules
Management port
Expansion slot
614 Mpps
586 Mpps
614 Mpps
586 Mpps
586 Mpps
System switching capacity *
826 Gbps
787 Gbps
826 Gbps
787 Gbps
787 Gbps
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
In: 7,000
Out:1,500
4.4 kg (9.70 lbs)
5.3 kg (11.68 lbs)
5.5 kg (12.13 lbs)
1.2 GHz dual-core CPU
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 2 GB
4MB
Without PoE load: ≤ 110 W
With PoE full load: ≤ 1,590 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
Frequency: 50 Hz/60 Hz
Rated voltage range: 240 V
LVDC input:
DC input:
DC input:
LVDC input:
DC input:
DC input:
120 years
110 years
94 years
90 years
95 years
10% to 90% (non-condensing)
5% to 95% (non-condensing)
45°C (113°F): 57.1 dB
27°C (80.6°F): 50 dB
45°C (113°F): 65 dB
27°C (80.6°F): 53 dB
45°C (113°F): 68 dB
RG-S5760-X Series
IGMP v1/v2/v3 and IGMP proxy
Dynamic ARP Inspection (DAI)
REUP, RLDP, and DLDP
1+1 power module redundancy
Forwarding mode
Store and forwarding
Syslog
RG-S5760C-48GT4XS-HP-E:
Power Modules
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
M5000X-4XS2CQ
600 W PoE AC power module
1000 W PoE AC power module
RG-PD600I-P-F
600 W PoE DC power module
Optical Modules
