RG-S5350-24GT4XS-P-E Switches - 1
RG-S5350-24GT4XS-P-E Switches - 2
RG-S5350-24GT4XS-P-E Switches - 3
RG-S5350-24GT4XS-P-E Switches - 4
RG-S5350-24GT4XS-P-E Switches - 5
RG-S5350-24GT4XS-P-E Switches - 6
RG-S5350-24GT4XS-P-E 24-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
Layer 3 Compact Access Switch for 10GE Uplink RG-S5350-24GT4XS-P-E
A full-gigabit access switch designed for large-sized enterprise and campus LANs, providing smart campus network solutions with four 10GE SFP+ ports for high-speed data transmission.
Industry-leading port surge protection capability of up to 10 kV Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments
CPU Protect Policy (CPP) is supported to control the packet type and traffic volume sent to the CPU, preventing high CPU usage. Virtual Switching Unit (VSU) ensures flexible networking and high performance.
Adopting advanced energy-saving technologies, the switch minimizes power usage and noise. With EEE, ports conserve energy by going dormant, activating only when traffic is detected.
The switch automatically completes registration and configuration after it accesses the all-optical network, achieving plug and play, no commissioning, and fast onboarding. A switch can be flexibly replaced based on service needs without reconfiguration. Service ports supports auto-sensing, achieving automatic O&M.
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
94 Mpps
125 Gbps
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Unit weight
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
Built-in power supply: 409 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
PIM SMv6, and PIM-SSMv6
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
Multiple AAA modes
BFD, NSR, VRRR, VRRP+
Basic LACP
SPAN, RSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
