Applicable in VSU networking scenarios, provides two uplink splitting ports, and works together with RG-MUX-8LC/LC-H.
8-port modular transparent distribution device used with splitters
RG-MUX-8LC/LC
RG-MUX-8LC/LC |
8-port transparent distribution device on the building side. A single port supports 1000M and 10G rates. |
Center Wavelength |
1271 nm to 1571 nm (CWDM) |
Channel Spacing |
20 nm |
Channel Bandwidth |
±6 nm |
Insertion Loss |
< 3.7 dB |
Return Loss |
> 45 dB |
Polarization Dependent Loss |
< 0.3 dB |
Adjacent Channel Isolation |
> 25 dB |
Non-adjacent Channel Isolation |
> 35 dB |
Connector |
LC/UPC |
Operating Temperature |
0°C to 55°C (32°F to 131°F) at the altitude of 0 m to 1800 m (0 ft. to 5905.51 ft.) |
Storage Temperature |
Operating Humidity |
5% RH to 95% RH |
Storage Humidity |
5% RH to 95% RH |
Standards |
Net Weight |
< 0.25 kg (0.55 lbs) |
RG-MUX-8LC/LC-H
RG-MUX-8LC/LC-H |
8-port transparent distribution switch on the building side. A single port supports 1000M and 10G rates. |
Center Wavelength |
Channel Spacing |
20 nm |
Channel Bandwidth |
±6 nm |
Insertion Loss |
< 2.6 dB |
Return Loss |
> 45 dB |
< 0.3 dB |
> 25 dB |
> 35 dB |
Connector |
LC/UPC |
–0°C to 55°C (32°F to 131°F, altitude: 0 ft. to 5905.51 ft.) |
5% RH to 95% RH |
Storage Humidity |
5% RH to 95% RH |
Standard |
Net Weight |
< 0.25 kg (0.551 lbs) |
RG-MUX-EXT
RG-MUX-EXT |
Expansion module of the transparent distribution device on the building side, which is also an optical splitter. It supports 2:N dual uplinks and is equipped with patch cables. |
Wavelength Range |
1271 nm to 1571 nm |
Channel Spacing |
20 nm |
Channel Bandwidth |
±6 nm |
Insertion Loss |
< 4.2 dB |
Return Loss |
> 45 dB |
< 0.3 dB |
Connector |
LC/UPC |
5% RH to 95% RH |
Storage Humidity |
5% RH to 95% RH |
Standard |
Net Weight |
< 0.15 kg (0.33 lbs) |
RG-MUX-BOX
RG-MUX-BOX |
Chassis for transparent distribution device on the building side with six slots, which is fit for 8-port transparent distribution device or splitter. |
5% RH to 95% RH |
Storage Humidity |
5% RH to 95% RH |
Net Weight |
0.9 kg (1.98 lbs) |
