Model | RG-S2628G-I | RG-S2652G-I |
Ports | 24 10/100BASE-T ports | 48 10/100BASE-T ports |
Fan Slots | Fanless |
Management Ports | 1 console port |
Switching Capacity | 64Gbps |
Packet Forwarding Rate | 14.1Mpps | 17.7Mpps |
Port Buffer | 1MB | 2MB |
ARP Table | 130 |
MAC Address | 16K |
Routing Table Size (IPv4/IPv6) | 32/16 |
ACL Entries | 500 | 1000 |
VLAN | 4K 802.1Q VLAN, Port-based VLAN, Protocol Based VLAN, Private VLAN,Share VLAN, Voice VLAN, Guest VLAN, Q-in-Q, GVRP |
QinQ | Basic QinQ |
Link Aggregation | AP, LACP |
Port Mirroring | Many-to-one mirroring, Flow-based mirroring, Over Devices Mirroring, AP-port Mirroring, RSPAN |
Spanning Tree Protocols | IEEE802.1d STP, IEEE802.1w RSTP, standard 802.1s MSTP, Port Fast, BPDU Filter, BPDU Guard, TC Guard, TC Protection, |
DHCP | DHCP Relay, DHCP Snooping. DHCP Client |
Multiple Spanning Tree (MST) Instances | 64 |
Maximum Aggregation Port (AP) | 120 |
VSU (Virtual Switch Unit) | Up to 8 stack members |
L2 Features | MAC, ARP, VLAN, Basic QinQ, Link Aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, MLD Snooping, DHCP, Jumbo Frame |
Layer 2 Protocols | IEEE802.3, IEEE802.3u, IEEE802.3z, IEEE802.3x, IEEE802.3ad, IEEE802.1p, IEEE802.1x, IEEE802.3ab, IEEE802.1Q, IEEE802.1d, IEEE802.1w, IEEE802.1s, IGMPSnooping v1/v2 |
Layer 3 Features | IPv4 static routing, IPv6 static routing |
Layer 3 Protocols (IPv4) | Static routing |
IPv4 Features | IPv4 ACL, Ping, Traceroute |
IPv6 Features | ICMPv6, IPv6 Ping, IPv6 Tracert, Manually configure local address, Automatically create local address, Neighbor discovery, 0-64 any length mask |
Basic IPv6 Protocols | IPv6 host management related information |
IPv6 Routing Protocols | Static routing |
Multicast | IGMP snooping, IVGL mode, IGMP filter and IGMP fast leave; |
ACL | Standard IP ACL (IP-based hardware ACL) |
QoS | 802.1p/DSCP/TOS traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WRR, SP+DRR; RED / WRED; Input / output port-based speed limit; Port-based traffic recognition; Each port supports 8 queue priorities |
IPv6 ACL | Support |
Reliability | VSU (virtualization technology for virtualizing multiple devices into 1), CPP, RLDP (Rapid Link Detection Protocol); |
Security | DHCP, ICMP, IP Source Guard, DOS Protection |
Manageability | SNMPv1/v2/v3, CLI (Telnet/Console), RMON (1, 2, 3, 9), SSH, Syslog, NTP/SNTP, Web |
Smart Temperature Control | Fan speed auto-adjustment; Fan malfunction alerts; Fan status check |
Smart Power Supply | Power management |
Other Protocols | FTP, TFTP, DNS client, DNS static |
Dimensions (W x D x H) (mm) | 440 × 200 × 44 | 440 × 260 × 44 |
Rack Height | 1RU |
Weight | 3.9kg | 4.2kg |
MTBF | >200K hours |
Power Supply | AC input: | AC input: |
Power Consumption | 17W | 28W |
Temperature | Operating temperature: 0°C to 50°C |
Storage temperature: -20°C to 70°C |
Humidity | Operating humidity: 10% to 90%RH |
Storage humidity: 5% to 95%RH |
Operating Altitude | -500M to 5,000M |
Model | Description |
RG-S2628G-I | RG-S2628G-I Ethernet Switch, 24-Port 10/100Base-T, 2-Port 1000base-T and 2 GE Ports SFP (Non-combo) |
RG-S2652G-I | RG-S2652G-I Ethernet Switch, 48-Port 10/100Base-T, 2-Port 1000base-T and 2 GE Ports SFP (Non-combo) |
Optional Accessories |
Mini-GBIC-SX-MM850 | 1000BASE-SX mini GBIC Transceiver (850nm) |
Mini-GBIC-LX-SM1310 | 1000BASE-LX mini GBIC Transceiver (1310nm) |
Mini-GBIC-GT | 1000BASE-TX, SFP Transceiver (100m) |
Mini-GBIC-LH40-SM1310 | 1000BASE-LH mini GBIC Transceiver (1310nm, 40km) |
Mini-GBIC-ZX50-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 50km) |
Mini-GBIC-ZX80-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 80km) |
Mini-GBIC-ZX100-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 100km) |
