Unmanaged Switches
Designed for IP Surveillance Scenario
Rich Port Types
Applicable to Various Scenarios
Standard SFP Ports
No Optical-copper Converter Required
Smart PoE Functions
Greatly Improving Terminal Stability
Large Buffer Design
No Stuttering of HD Videos
RG-S1800-P Series
PoE+ on All Ports
Rich Port Types
The RG-S1800 series offers a
broad range of port types,
including 8/16/24 FE/GE access with
copper/SFP uplink, which can be
used in various SMB scenarios
and IP surveillance scenarios.
Standard SFP Ports
The RG-S1800 series (except for RG-S1808,
RG-S1808G and RG-S1809-P) is equipped with
standard SFP ports, which prevents SPOF and
reduces costs by 20%.
Large Buffer Design
The large buffer design is especially
designed for IP surveillance and
ensures smooth HD video
transmission.
PoE+ on All Ports
Making Your Network More Efficient and Economical
RG-S1800-P series supports high-power (30W)
electricity supply, which is applicable to various
terminal types.
Smart PoE Functions
Improving Terminal Stability by More Than 30%
RG-S1800-P series can automatically negotiate the power based on the terminal type and provide short circuit protection. The switches automatically power off upon a short circuit.
Ruijie Networks
