48-Port GE Electrical Layer 3 Managed Access Switch with PoE+, Four 10G Uplink Ports, RG-S5310-48GT4XS-P-E
176Gbps/336Gbps
Forwarding rate
131Mpps
Model RG-S5300-24GT4XS-E RG-S5300-48GT4XS-E RG-S5310-24GT4XS-P-E RG-S5310-48GT4XS-P-E
Basic Features
Fixed Ports 24 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports 48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports 24 x 10/100/1000BASE-T support PoE+, 4 x 1G/10G SFP+ ports 48 x 10/100/1000BASE-T support PoE+, 4 x 1G/10G SFP+ ports
Power Slot NA NA 2 2
Switching Capacity 336 Gbps/3.36 Tbps 432 Gbps/4.32 Tbps 336Gbps/3.36Tbps 432Gbps/4.32Tbps
Forwarding Rate
96Mpps/126Mpps 132Mppss/166Mpps 96Mpps/126Mpps 132Mppss/166Mpps
MAC Address 32K
ARP Table 2000 4000
Routing Table Size (IPv4/IPv6) 4000 (IPv4/IPv6)
ACL Entries In: 3,500
Out: 1,500
Software Features
802.1Q VLAN 4K 802.1Q VLAN
MAC-based VLAN
QinQ Basic QinQ
ACL Standard IP ACLs (IP-based hardware ACLs)
MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type)
Expert-level ACLs (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time)
ACL 80 IPv6 ACLs
Global ACLs ACL redirection
QoS Port traffic identification Port traffic rate limiting
802.1p/DSCP/ToS traffic classification Eight priority queues per port
SP, WRR, SP+WRR, RED/WRED queue scheduling mechanisms
Mirror One-to-one mirroring, many-to-one mirroring, and one-to-many mirroring RSPAN
DHCP DHCP server DHCP client
DHCP snooping DHCP relay
IPv6 DHCP snooping IPv6 DHCP client IPv6 DHCP relay
Multiple Spanning Tree Protocol (MSTP) Instances 65
Maximum Aggregation Port (AP) 128 (max. 8 ports per group)
Security Features The following are supported:
3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses
Port- and MAC-based 802.1x authentication MAB authentication
Portal authentication and Portal 2.0 authentication ARP-check
Gateway ARP spoofing prevention Broadcast storm suppression
Hierarchical management of administrators and password protection RADIUS and TACACS+ AAA (IPv4/IPv6) for device login management
SSH and SSH V2.0
IP source guard CPP, NFPP
ERPS G.8032 v1/v2, Sing-ring, Tangent-ring, Intersecting-ring, Load balancing, compatible with products of this protocol.
PoE NA IEEE 802.3at/802.3af
IP Routing IPv4/IPv6 static routing
RIPv1 & RIPv2, RIPng, OSPFv2, OSPFv3, BGP, and
ISIS Routing policy, MLD Snooping
IPv6 IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 Tracert, and IPv6 multicast
VSU Features 4
Zero Configuration CPE WAN Management Protocol (CWMP(TR069))
Management Features SNMPv1/v2c/v3, CLI(Telnet/Console), RMON(1, 2, 3, 9), SSH, Syslog, NTP/SNTP, Web, CLI(Telnet/Console), RMON, SSH, Syslog/Debug, NTP/SNTP, FTP, TFTP, Web, and sFLOW
Physical Features
Dimensions (W × D × H) 442 mm × 420 mm × 43.6 mm
Rack Height 1RU
MTBF (hours) >200K
Power Supply Single fixed power supply
Rated voltage range: 100 V to 240 V Maximum voltage range: 90 V to 264 V Frequency: 50/60 Hz
Dual power supply
Rated voltage range: 200 V to 240 V Maximum voltage range: 176 V to 264 V Frequency: 50/60 Hz
Fan Fan speed regulating and alarm function
Power Consumption ≤40 W ≤55 W PoE: <810W (PoE full load) PoE: <1570W (PoE full load)
PoE Budget N N RG-PA600I-P-F:370W(Dual 740W)
RG-PA1000I-P-F:740W(Dual 1480W)
Port lightning protection 10kV
Temperature Operating temperature: 0℃ to 45
Storage temperature: -40℃ to 70℃
Relative Humidity Operating humidity: 10% to 90%RH Storage humidity: 5% to 95%RH
Operating Altitude 0m to 5,000m
1. This content is applicable only to regions outside the China mainland. Ruijie reserves the right to interpret this content.
2. The value before the slash (/) refers to the device's switching capability, while the value after the slash (/) refers to the system's switching capability.
Model Description
RG-S5300-24GT4XS-E 24 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports
RG-S5300-48GT4XS-E 48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports
RG-S5310-24GT4XS-P-E 24-Port 10/100/1000BASE-T, and 4 1G/10G SFP+ Ports, support PoE+, max 740w for PoE, 2 modular power supply slots (at least one power module needed)
RG-S5310-48GT4XS-P-E 48-Port 10/100/1000BASE-T, and 4 1G/10G SFP+ Ports, support PoE+, max 1440w for PoE, 2 modular power supply slots (at least one power module needed)
RG-PA600I-P-F AC Power Module, 370W Power Budget for PoE, up to 24 PoE ports or 12 PoE+ ports (only for RG-S5310-24GT4XS-P-E, RG-S5310-48GT4XS-P-E)
RG-PA1000I-P-F AC Power Module, 740W Power Budget for PoE, up to 48 PoE ports or 24 PoE+ ports (only for RG- S5310-24GT4XS-P-E, RG-S5310-48GT4XS-P-E)
Mini-GBIC-GT 1000BASE-TX, SFP Transceiver (100m).
Mini-GBIC-SX-MM850 1000BASE-SX, SFP Transceiver, SM (850nm, 500m, LC).
Mini-GBIC-LX-SM1310 1000BASE-LX, SFP Transceiver, SM (1310nm, 10km, LC).
Mini-GBIC-LH40-SM1310 1000BASE-LH, SFP Transceiver, SM (1310nm, 40km, LC).
Mini-GBIC-ZX100-SM1550 1000BASE-ZX100, SFP Transceiver, SM (1550nm, 100km, LC).
XG-SFP-SR-MM850 10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC)
XG-SFP-LR-SM1310 10GBASE-SR, SFP+ Transceiver (1310nm, 10km, LC)
XG-SFP-ER-SM1550 10GBASE-SR, SFP+ Transceiver (1550nm, 40km, LC)
