RG-S2915-10GT2MS-P-L, 10-Port Gigabit Layer 2+ Managed PoE+ Switch with Two 2.5GE Uplink SFP Ports
  • 2.5G uplink, which can upgrade gigabit networks to 10GE networks, and meet 40GE/100GE networking requirements in the future
Killer Layer 2+ Access Switch
Applications
Switching capacity:
30 Gbps
Forwarding rate:
and Uninterrupted Connection
