RG-S2910-24GT4XS-UP-H(V3.0), 24-Port Gigabit L2+ Managed POE Switch with SFP+
Simple Deployment
Shortened construction period
Reduced costs
Secure and Reliable
Easy O&M
RG-S2910-24GT4SFP-UP-H(V3.0)
System
Up to 256Gbps
Up to 256Gbps
42Mpps/96Mpps
Up to 96Mpps
Input voltage
PoE power supply
10% to 90% RH
5% to 95% RH
4K VLANs
IP subnet-based VLAN
Standard IP ACL
Extended IP ACL
Time range-based ACL
Global ACL
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
Layer 2 protocols
Invalid MAC address filtering
Trusted ARP
SSH and SSHv2.0
Cable diagnostics
Cable detection
Port sleeping
Port sleeping
IEEE 802.3af, IEEE 802.3at,
Interface priority
IPv4/ IPv6 static route
Routing policy
IPv6
Basic protocols
VSU features
Zero Touch Provisioning (ZTP)
Management features
●  Purchase the chassis.
24 10/100/1000BASE-T ports for downlink and 4 Gigabit SFP ports (non-combo) for uplink. To support POE+, POE, max 370w for PoE (The model on the product panel is still RG-S2910-24GT4XS-UP-H, and the corresponding hardware version number is V3.00 and above)
24-Port 10/100/1000BASE-T,and 4 1G/10G SFP+ Ports, Support PoE+, PoE,max 370w for PoE(The model on the product panel is still RG-S2910-24GT4XS-UP-H, and the corresponding hardware version number is V3.00 and above)
Optical Modules
1000BASE-GT mini-GBIC module (optional)
Single-port 1000BASE-SX mini GBIC module (LC connector) (optional)
Single-port 1000BASE-LX mini GBIC module (LC connector) (optional)
Single-port 1000BASE-LH mini GBIC module (LC connector) with a link length of up to 40 km (optional)
Single-port 1000BASE-ZX mini GBIC module (LC connector) with a link length of up to 50 km (optional)
Single-port 1000BASE-ZX mini GBIC module (LC connector) with a link length of up to 80 km (optional)
1000BASE-ZX mini GBIC module with a link length of up to 100 km (optional)
