Home> Products> Switches> Access Switches>
RG-S2910-24GT4SFP-UP-H(V3.0)
24-Port Gigabit L2+ Managed HPOE Switch
● Power Redundancy Support
More+
HPoE
HPoE
Simple Deployment
Shortened construction period
Reduced costs
Simple Deployment
Secure and Reliable
Easy O&M
RG-S2910-24GT4XS-UP-H
RG-S2910-10GT2SFP-UP-H
Up to 256Gbps
Up to 256Gbps
Up to 256Gbps
42Mpps/96Mpps
Up to 96Mpps
Up to 18Mpps
16K
64 (IPv4/IPv6)
In: 1500
Out: 500
In: 1500
Out: 500
In: 750
Out: N/A
Basic QinQ, Flexible QinQ
OpenFlow
VSU Stack Members
Up to 9 stack members
VSL
Layer 3 Features
ARP, IPv4/v6
IPv4 Routing Protocols
Static Routing, RIPng, OSPFv3
GR for RIP
GR for RIP
GR for RIP
Dimensions (W x D x H) (mm)
440×260×44
440×260×44
340×260×44
361712 hours
388055 hours
408710 hours
Common Mode 6KV
Frequency: 50Hz to 60Hz
<460W
<460W
<630W
PoE Power Consumption
Storage humidity: 5% to 95%RH
Device Security
In tough environments with thunderstorms and electromagnetic interference, devices are prone to damages caused by strong transient currents.
HPoE provides multiple protection mechanisms;
Overcurrent protection, preventing device damages even upon short circuits;
Up to 6KV port lightning protection, ensuring stable operation in various tough environments.
In independent deployment mode, strong-current cables are used in most cases. The voltage of power cables is higher than the safe voltage limit (36 V), and may cause accidents.
The HPoE technology complies with international power supply standards and features a low voltage and high safety, ensuring safety of O&M and working personnel.
Network Security
Support for various types of ACL, port security, and IP + MAC + Port binding technologies, effectively preventing various ARP frauds
Proactive prevention against DoS and DDoS attacks
Support for the CPU Protect Policy (CPP) and Network Foundation Protection Policy (NFPP), effectively preventing attacks against standalone devices and the entire network
Network Security
Stable and Reliable Power Supply
High-power (60 W) and long-distance (100 m) power supply is provided. Compared with the conventional centralized power supply mode:
The HPoE technology complies with international standards; adjusts line loss and lowers voltage intelligently, reducing errors caused by manual adjustment; and provides independent power supply over single ports, achieving faulty domain isolation.
Quick and Easy to Build
No Power Cable Required in Scenarios with Network Cables
To supply electricity to high-power STAs (> 30 W), an independent power supply system needs to be deployed, and the resulted grooving, pipeline layout, wire-threading, debugging, and wall and floor embellishment cause highly complex construction and a long construction period.
Only the network cable is required for power supply and data transmission via HPoE.
Reduced Cost & Less Investment
30% Cost Off in Typical Configuration Mode
If an independent power supply system is deployed, materials such as the power chassis, power cables, power socket, and power adapters are required, while a construction fee will also be incurred, resulting in high overall fees.
In HPoE power supply mode, the previously mentioned materials and accessories are not required, which reduces overall fees by 30% in typical deployment scenarios.
8路50密网络电源部署合计对比图
Remote Restart for Easy O&M
In conventional power supply mode, the power supply system is not connected to the network. When a device is faulty, its power supply must be located for a manual restart, which can rapidly resolve most problems. However, if the power supply of the faulty device cannot be restarted due to environmental restrictions, other more complex solutions need to be adopted.
HPoE enables the power supply system to be connected to the network. Consequently, a faulty device can be remotely restarted using a PC to rectify faults rapidly and improve O&M efficiency.
远程重启 轻松运维
The VSU technology virtualizes multiple physical devices into one logical device and uses a single IP address, Telnet process, and CLI for management.
Multiple devices are managed as one device, ensuring high management efficiency.
On-Demand Service Management and Control
  • Scheduled power-on/off of STAs:
    The STA power-on/off time can be customized based on user habits.
  • Uninterrupted power supply during hot start:
    Power supply to STAs is not interrupted during restart of the HPoE power supply host.
  • Power status check at any time:
Hardware Installation Guide
Software Download
PoC Guide
