Home> Products> Switches > Core Switches>
RG-N18000 Switch Series
Ruijie Newton 18000 Switch Series (RG-N18000) is industry leading in supporting cloud data center with a broad spectrum of specialized campus network features. Ruijie RG-N18000 core switches achieve cloud network integration, virtualization, and flexible deployment to fulfill the evolving next-gen cloud architecture requirements.
Ruijie brings you an innovative “Network Cloud Mode” featuring strong cloud and light access: Building a strong core (unified gateway, authentication, multiservice) for light access. All service channels including the cloud data center and cloud campus network can move to the cloud, building a true channel connecting the services and end users. The feature achieves network resources pooling, requirement-based distribution and flexible expansion.
Ruijie RG-N18000 Series deploys an advanced software architecture design and is one of the world’s leading core switches with the highest specifications. The series supports CLOS switching architecture and offers sustaining bandwidth upgrade and service support capacities. Single slot offers forwarding rates of up to 1.92Tbps and single chassis can support 96 100GE, 288 40GE or 1152 10GE full line rate interfaces.
RG-N18000 Series has 3 models - RG-N18014, RG-N18010 and RG-N18007 - to meet various port density and performance requirements. The switches deliver excellent investment protection and are suitable for deployment in a wide range of settings such as data center, MAN, campus network or integrated network of data center and campus network.
More+
Cloud Network-oriented
New-Generation Core Switch
TOLLY Group
RG-N18000 Series support
Next-Generation Multi-Process
Modular OS
Rich Data Center Features
VSU Multiple-to-One
VSD One-to-Multiple
100K Concurrent Online STAs
Only one switch to manage on a simplified campus network
Newton 18000 will be the unified gateway
170K ARP entries and 170K IPv4 STAs; 120K ND entries and 120K IPv6 STAs
Highest gateway capabilities globally, 10 times of the industry level, ensuring access for all kinds of STAs
Outstanding Authentication Experience
How can 100K STAs be authenticated and access the network more rapidly?
The supervisor module of the Newton 18000 switch supports CPUs with a maximum of 32 cores. Tens of thousands of STAs can be authenticated within one minute.
The quantity of CPU cores supported by the Newton 18000 series switchs’ supervisor module is 8 times the core quantity of high-end core switches in the industry
The authentication speed of a single card is 4 times faster than that of high-performance BRAS devices
Only One Switch to Manage
The Newton 18000 switch serves as the unified gateway, and provides functions such as unified access authentication, unified security policies, and unified wireless control
The access or convergence switches can form a network via only the VLAN isolation function
Service cards ranging from 1GE to 100GE and multi-service cards are provided, meeting service requirements of a campus network, data center, and MAN
The simplified campus network can be managed by only managing and monitoring the core switches
Future-oriented SDN
Future-oriented SDN
Newton 18000 switches support the OpenFlow 1.3 protocol, ensuring smooth upgrade to a SDN network at any time
Ruijie Networks provides the SDN controllers with standard RESTful interfaces
Cooperation on SDN with multiple industries such as governments, scientific researchers and educational institutions has been successfully carried out
Sole Provider of Overall Campus Network Solution in the Industry
The simplified network is the sole overall solution that can provide an authentication device, authentication system, and charging system
Unified brand products ensure the highest coupling and compatibility in the industry
The solution is continuously improving O&M efficiency
TOLLY Group
Supported VSU and VSD
Comparison of Port Bandwidths
Frame Size (bytes)
Latency Comparison
Frame Size64-byte128-byte512-byte1518-byte4096-byte9216-byte
Cut-Through Latency (μs)0.5320.5450.5880.5860.5860.586
Store -and-Forward LIFO Latency (μs)0.6500.6510.6660.6650.6650.665
Frame SizeCut-Through Latency (μs)Store -and-Forward LIFO Latency (μs)
64-byte0.5320.650
128-byte0.5450.651
512-byte0.5880.666
1518-byte0.5860.665
4096-byte0.5860.665
9216-byte0.5860.665
Port Buffer Comparison
Port Buffer -
10GbE port2
MAC Table
Capacity3
Capacity3
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
318.98MB, 268.16ms for 9216-byte frames512,000170,000512,000 IPv4 or 512,000 IPv6128,000100,000 concurrent users1,200 requests per second2,700 users per second
Port Buffer -
10GbE port2
MAC Table
Capacity3
512,000
Capacity3
170,000
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
128,000
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance5
Entry Comparison
Port Buffer -
10GbE port2
MAC Table
Capacity3
Capacity3
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port2
MAC Table
Capacity3
512,000
Capacity3
170,000
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
28,000
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
The test results show that:
Up to 512K MAC entries
Port Buffer -
10GbE port2
MAC Table
Capacity3
Capacity3
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port2
MAC Table
Capacity3
512,000
Capacity3
170,000
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
128,000
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance5
Entry Comparison
Port Buffer -
10GbE port2
MAC Table
Capacity3
Capacity3
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
Port Buffer -
10GbE port2
MAC Table
Capacity3
512,000
Capacity3
170,000
FIB Table
Capacity4
IPv6 Neighbor
Cache Table
Capacity3
28,000
802.1x
Authentication
Capacity5
802.1x
Authentication
Performance
DHCP Server
Performance 5
 Uplink FailureMain and Backup
control modules switch
Backup control module failureMain switch failureBackup switch failure
Average Convergence Time30ms0011ms11ms
Uplink Failure30ms
Main and Backup
Backup control module failure0
Main switch failure11ms
Backup switch failure11ms
Uplink failover: 35 ms
Stability
Tolly Certified Features
OpenFlow 1.3 Main Feature
Modular System(ISSU) for Control Modules
Stateless Process Restart
Hot Process Patching
N+1 Fabric Module Redundancy
Hot Swappable Fabric Module
Power Consumption Analysis
 Without Any
Line Card
Load All
Modules - 0%
Traffic
Load All
Modules - 30%
Traffic
Load All
Modules - 100%
Traffic
Difference
between 100%
traffic and without
any line card
Average Apparent
Power per line
card with 100%
traffic
Average Apparent
Power per 40GbE
port with 100%
traffic
Apparent Power1.456VA2.573VA2.742VA3.108VA1.652VA206.5VA8.6VA
 Apparent Power
Without Any
Line Card
1.456VA
Load All
Modules - 0%
Traffic
2.573VA
Load All
Modules - 30%
Traffic
2.742VA
Load All
Modules - 100%
Traffic
3.108VA
Difference
between 100%
traffic and without
any line car
1.652VA
Average Apparent
Power per line
card with 100%
traffic
206.5VA
Average Apparent
Power per 40GbE
port with 100%
traffic
8.6VA
Ultra-Simplified Solution for Campus and Data Center Networks
To meet new challenges from evolving application environments, the market-leading Ruijie RG-N18000 Series delivers an innovative heterogeneous solution to power both campus and data center networks.
The RG-N18000 Series operates as the core of unified authentication and gateway in the ultra-simplified network solution. The switch achieves centralized authentication of wired and wireless networks on the core device via the built-in/external 802.1X/Portal authentication system. It can eliminate all the differences between access layer device performance and access mode. The RG-N18000 Series supports ≥170K ARP capacity, concurrent ≥60K IPv4/IPv6 dual stack devices with centralized authentication and authentication speed of 1000 devices per second. The web noise reduction feature can prevent illegal authentication packets to protect users’ Internet authentication experience. With Ruijie SAM, the RG-N18000 Series can also achieve refined management such as traffic billing and traffic control.
Ruijie RG-N18000 Series can act as the core of unified authentication and gateway of the campus network to offer simplified network experience for users. As the centralized authentication gateway, the core device can achieve unified assignment of security policies. The access layer and aggregation layer is only responsible for Layer 2 forwarding. As the device maintenance is simpler, the performance capacity is no longer a bottleneck. The core layer device provides rich features, high performance and high reliability. The centralized management of network management policies facilitates security monitoring, network expansion and new service development. The Ruijie RG-N18000 Series supports multiple authentication modes such as Portal/ 802.1X. MAC. Different management modes and technologies will be deployed in different scenarios according to different user requirements of the campus network so as to provide targeted and high-availability technologies and solutions.
Cloud Data Center Network
Ruijie RG-N18000 Series can also act as the core of the Cloud Data Center Network Solution, and provide a robust and comprehensive set of features that meets the demanding requirements of virtualization and automation in present and future data center environments. A variety of features are embedded in the Ruijie RG-N18000 Series such as Layer 2 Generic Routing Encapsulation (GRE) and Virtual Ethernet Port Aggregator (VEPA).
World’s Leading Cloud Network Core
CLOS Non-blocking Architecture
Advanced CLOS Architecture
Scalable Performance for Future Development
Ruijie RG-N18000 Series single slot supports bandwidth of 2Tbps and it is scalable to 4Tbps. The series also supports high-density 40GE and 100GE Ethernet ports to meet the evolving requirements of cloud computing data center in the coming decade.
Next-Gen Cloud Infrastructure
Delivering high-quality cloud-based experiences to clients efficiently requires an intelligent next-generation cloud infrastructure that Ruijie offers. Ruijie RG-N18000 Cloud Network Core Switch Series can operate as the core of the Cloud Data Center Network, and provide a robust and comprehensive set of features that meets the demanding requirements of virtualization and automation in present and future data center environments. A variety of features are embedded in the Ruijie RG-N18000 Series such as Layer 2 Generic Routing Encapsulation (GRE) and Virtual Ethernet Port Aggregator (VEPA). Full details will be discussed in the coming sections.
Virtual Switch Unit 3.0 (VSU)
Virtual Switch Device (VSD)
The Ruijie RG-N18000 Series supports Virtual Ethernet Port Aggregator (VEPA) of the IEEE802.1qbg standard. Data traffic from the server VM can be diverted to the physical network devices for “hard-switching”. This completely eliminates problems such as uncontrollable monitoring of VM traffic, incapability of unified policy deployment and server resources occupation caused by traditional “soft-switching”. All the features together optimize the next-gen data center network solution to fit into the virtual computing environment.
Virtual Machine Perception and Policy Auto-migration
The VM perception and automatic migration of policies features enable centralized deployment of VM traffic security policy in a large-scale server virtualization environment. Married with data center network management platform, data center switches, and VM management platform, it realizes simultaneous policy migration as virtual host can migrate smoothly within the network. It totally gets rid of security loopholes and hence lessens network maintenance workload.
Core Concepts
Solution Components
●Hardware Switching Devices:
Ruijie Newton 18000 and S6000 series platforms will fully support OpenFlow modular hardware switching
●SDN Controller RG-IONC
○MPLS L3 VPN service
RG-N18007
RG-N18010
RG-N18014
Module Slots
7 (2 for control engines)
14 (2 for control engines)
18 (2 for control engines)
Modular Power Slots
8 (all for system power)
Fan Slots
Control Engine Slots
Service Module Slots
Fabric Engine Slots
Backplane Bandwidth (per slot)
Up to 320Gbps (bidirectional)
Up to 1.92Tbps (bidirectional)
50Tbps/208.5Tbps
80Tbps/333.6Tbps
120Tbps/500.4Tbps
900Mpps
11,520Mpps
17,280Mpps
Max. Number of 10GE Ports
Up to 240
Up to 768
Up to 1,152
Max. Number of 40GE Ports
Up to 60
Up to 192
Up to 288
Up to 16MB
Up to 24GB
Up to 24GB
Up to 170K
Up to 512K
Routing Entries
Up to 384K
Routing Table Size
(IPv4/IPv6)
Up to 12K/6K
Up to 384K/128K
Up to 384K/128K
Multicast Entries
(IPv4/IPv6)
Up to 16K/8K
Up to 8K
4K
Basic QinQ, Flexible QinQ
AP, LACP
STP, RSTP and MSTP
64 (not include default 0)
Up to 256
Up to 2K
L2 GRE, Virtual Ethernet Port Aggregator (VEPA)
OpenFlow
Up to 2 stack members
VSD (Virtual Switch Device)
Up to 12 VSD units
Jumbo Frame, 802.1Q, STP, RSTP, MSTP, Port-based VLAN, Super VLAN, Private VLAN, Protocol-based VLAN, IP subnet-based VLAN, GVRP, QinQ, Flexible QinQ, LLDP, ERPS (G.8032)
Layer 3 Features
ARP, IPv4/v6, PBR v4/v6
Layer 3 Protocols (IPv4)
IPv6 Tunnel Features
MPLS forwarding, MPLS VPN, VPLS/VPWS , LDP, LSP
ACE Capacity
Up to 8K
802.1p, Queue scheduling mechanisms (SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR, and 8 hardware queues at egress ports ), RED/WRED, Input/output port-based speed limit
Support EEE (802.3az)
Hot Patch
Smart Power Supply
(W x D x H) (mm)
442 x 598 x 352.8
442 x 836 x 797.3
442 x 814 x 886.2
8RU
18RU
20RU
30.2kg
103.32kg
107.55kg
>200K hours
180-264V~1600W (PoE)
210-264V~3000W (PoE)
<432W
<730W
<860W
PoE Power
<6,000W
<6,000W
-500m to 4,000m
Weight and Typical Power
Component
Maximum Power
Main Chassis
30.2kg
432W
103.32kg
730W
107.55kg
860W
Control Engine
  • M18007-CM
1.68 kg
40W
  • M18007-CM II
2.0kg
102W
  • M18007-CM II Lite
2.0kg
102W
  • M18010-CM
1.68kg
40W
  • M18010-CM II
2.04kg
95W
  • M18014-CM
3.22kg
40W
  • M18014-CM II
3.58kg
100W
Fabric Engine
  • M18010-FE-C I
2.72kg
90W
  • M18010-FE-D I
2.8kg
107W
  • M18010-FE-D III
3.36kg
313W
  • M18014-FE-D I
3.76kg
158W
  • M18014-FE-D III
4.56kg
425W
  • RG-PA1600I
2.04kg
  • RG-PA600I
1.64kg
  • RG-PA1600I-P
1.6kg
  • RG-PA1600I-PL
1.6kg
  • RG-PA3000I-PL
1.6kg
  • RG-PD1600I
1.6kg
  • RG-PD600I
1.3kg
Line Card & Service Module
  • M18000-44SFP4XS-ED
3.76kg
135W
  • M18000-44SFP4XS-EF
3.86kg
175W
  • M18000-44SFP4XS-CB
5.06kg
267W
  • M18000-48GT-ED
3.7kg
95W
  • M18000-48GT-EF
3.8kg
175W
  • M18000-48GT-P-ED
4.04kg
95W
  • M18000-24GT20SFP4XS-ED
3.76kg
100W
  • M18000-08XS-ED
3.42kg
85W
  • M18000-08XS-EF
3.52kg
120W
  • M18000-16XS-CB
4.20kg
156W
  • M18000-16XT-CB
4.50kg
250W
  • M18000-40XS-CB
5.20kg
296W
  • M18000-48XS-DC
4.25kg
232W
  • M18000-24XS4QXS-DC
4.0kg
208W
  • M18000-12QXS-DC
3.92kg
200W
  • M18000-24QXS-DB
4.95kg
374W
Multiservice Module
  • M18000-MSC-ED
4.58kg
190W
The Ruijie Newton 18000 platform is applicable to a wide range of deployment scenarios. The series can act as the core for large campus network, data center network, integrated network of data center and campus network, and large MAN. Respective illustrations are shown below.
Large Campus Network Core
Large MAN Core
RG-N18014
RG-N18010
RG-N18007
M18014-CM II
M18014-CM
N18014 Control Engine
M18010-CM II
M18010-CM
N18010 Control Engine
M18007-CM
M18007-CM II
M18007-CM II Lite
M18000-MSC-ED
2. Power Supply
RG-PA600I
RG-PD600I
RG-PA1600I
RG-PD1600I
RG-PA1600I-PL
RG-PA3000I-PL
3. Fabric Engine
M18014-FE-D III
M18014-FE-D I
M18010-FE-D III
M18010-FE-D I
M18010-FE-C I
4. Line Card & Service Module
M18000-44SFP4XS-ED
M18000-44SFP4XS-EF
M18000-44SFP4XS-CB
M18000-48GT-ED
M18000-48GT-EF
M18000-48GT-P-ED
M18000-08XS-ED
8 10GE fiber ports (SFP+, LC)
M18000-08XS-EF
M18000-16XS-CB
16 10GE fiber ports (SFP+, LC)
M18000-16XT-CB
16 10GE copper ports (RJ45)
M18000-40XS-CB
40 10GE fiber ports (SFP+, LC)
M18000-48XS-DC
48 10GE fiber ports (SFP+, LC), support VXLAN
M18000-24XS4QXS-DC
24 10GE fiber ports (SFP+, LC) + 4-port 40GE optical interface module (QSFP+, MPO), support VXLAN
M18000-12QXS-DC
12 40GE fiber ports (QSFP+, MPO), support VXLAN
M18000-24QXS-DB
5. Transceiver and Cable
40G Cable for QSFP+, 5M
40G Cable for QSFP+, 10M
40G-QSFP-LR4-PSM-SM1310
QSFP-MPO8-4LC-SM-1M
QSFP-MPO8-4LC-MM-1M
FE-SFP-LX-MM1310
FE-SFP-LH15-SM1310
CON-DB9/RJ45-2M
Case Study
More >
  • Sales Enquiry
